Oil pump change
Old Sep 5, 2020 | 12:16 PM
Rick L'Esperance's Avatar
Default Oil pump change
How to replace oil pump in my 2003 h2?
Little point for tips or tricks to make the change go smoothly...
Have no oil pressure...
New oil pressure sensor installed...same...
Old Sep 5, 2020 | 01:41 PM
the o-ring that seals the oil pickup tube to the oil pump is notorious for causing your issue. it fails or shrinks letting air in which will not let the pump prime.
Old Sep 5, 2020 | 04:54 PM
Always monitor the engine oil, keep it clean, and only use full syn! In the meantime drop the pan, clean the screen, and as Bronx stated, replace the pickup tube seal. Recheck oil pressure.
roadfire
Feb 20, 2020 09:55 PM
rachelellis
Feb 9, 2020 11:04 AM
Joeybiff
Jan 10, 2019 03:34 PM
DanH3
Jul 11, 2014 08:15 AM
Limo-Scene Jackie
May 18, 2013 01:27 PM
