Oil cooler help
Old Sep 30, 2025 | 08:26 PM
Beachrider99's Avatar
Originally Posted by H2-SUT
I think I would second Gavin's accessment, the LQ4 doesn't really need the oil cooler. I had towed a number of times with both my 05 and 06 H2 and neither of them ever got warm enough to be a concern.
Now that's a little different with the 08/09, if your in that group the 6.2L does run a bit warmer but if your not towing anything heavy and the kind of person that changes your oil on the lower mileage side you should be ok.
The Derale cooler would be a good solution and should provide good results. Plus getting a possible failure point out the radiator is a real plus too! Myself, I would love getting both the Trans and oil cooler lines outside the radiator as well the failure of either one is a costly problem!
thanks I appreciate it. I’ll be testing it on a 4 hour road trip then 7 days in only sand 4hour trip home next week. I put the block off plate on because I don’t have time to get the serape and get everything mounted properly.
Old Oct 1, 2025 | 07:07 AM
Gavin Costigan's Avatar
Originally Posted by RobertDez
Mounted under the radiator. Use the Derale oil cooler line block. AN10 fittings with steel braid hose. Works better than the OEM in the radiator tank...
I used the derale adapter on mine but it still goes into the radiator. My expensive but better solution then oem cooler lines. I trust when you say it works, but how does it even get any air being under the radiator?
Old Oct 1, 2025 | 02:23 PM
RobertDez's Avatar
There's actually quite a bit of airflow under there. If you think about it, the OEM design in the radiator tank is sitting in 200° coolant much of the time. It doesn't take much to do a better job cooling the oil out in the open air. I wasn't sure at first, figured I'd mount it there and test it while pulling my 8,000 lb trailer a couple times. In the middle of summer going up over santiam pass, I've seen the oil temperature hit 205°.... But most of the time with my trailer it stays just under 200°. Without my trailer it runs about 170 to 180 running down the freeway.
Gavin Costigan
Mar 22, 2023 03:34 PM
ryaleon
Apr 27, 2019 05:39 PM
drewandsteph
Jan 22, 2018 07:50 AM
Hummerrican
Jul 19, 2015 06:01 AM
Happy Hummer
Aug 31, 2012 06:36 PM
