No Cruise or Brake Lights
Old Jun 8, 2011 | 07:35 PM
Csdisme's Avatar
Default No Cruise or Brake Lights
The cruise and the brake lights in my '04 H2 are not working. The strange part is, the middle brake light is working though. The cruise started acting up a few weeks ago turning off by itself and being difficult to engage. Now it wont engage at all. Then yesterday someone yelled to me at a traffic light that I didn't have any brake lights except the middle one. Too coincidental not to be related.
I checked the fuses on both the engine panel and the dash panel, both good. I tried new bulbs, no go there. I checked voltage at the fuse panel, it's getting voltage when the brake pedal is pressed.
I dont know what else to check at this point. Anyone have any ideas?
Thanks in advance for any help.
Old Jun 10, 2011 | 10:16 PM
Chunk54's Avatar
A lot of GM's use a 2 wire lead off of the brake light switch. It could still be the switch, especially since it is turning off the cruise. Some even use a switch in the hydraulic system of the brakes for abs & third brake light, kinda like Ford does. Does this only happen when the tail lights / running lights are on? Do the turn signals work properly? You could have a wire shorted in back or a bulb socket shorted. Also check any trailer wiring harness, where it connects to the tail light wiring and where the trailer would plug in. It turn signals aren't right, the problem could go into a hazard switch. hth.
Old Feb 24, 2019 | 02:49 PM
rswizards's Avatar
Default 2003 h2 no brake lights or cruise
so i've replaced the blubs &the brake stop switch( brake pedal switch) i have taillights when the they are on. blinker works. reverse.. no brake or 3rd brake light... fuse is good.... any ideas?
thanks
Old Mar 4, 2019 | 07:42 PM
thanks
Sure is good that you dug up this 7.5 year OLD thread to ask a question.
READ: Old Threads/'Necro-Bumping'
Old Mar 5, 2019 | 07:20 AM
oceanbrave's Avatar
No brake lights = No Cruise Control
The low resistance of the bulbs is monitored by BCU/ECU which is why replacement LED brake light bulbs can be problematic (I believe)
Old Mar 5, 2019 | 07:47 AM
calif phil's Avatar
Who cares if it's an old thread? If it's relevant I am ok with it. I would look at the connector under the left rear of your H2. Maybe it corroded and making a bad connection. All the rear wiring harness passes through that connector.
Old Mar 6, 2019 | 04:25 AM
oceanbrave's Avatar
thanks
From what you've said, if there's 12V on the bulbs it must be a ground distrubution issue, as you can see from the diagram the Center Stop Lamp is grounded differently which is probably why it works.
To prove a point manually ground the lamps to the chassis, they must come on if there's is 12v on them.
Old Mar 10, 2019 | 04:18 PM
rswizards's Avatar
Default Best Buy at fault
Turns out.. the put a diode on the brake pedal switch. Fried my inside fuse box.. removed diode, replaced fuse block. All good now
tqu9047
Apr 22, 2017 04:03 AM
Ralf Lipp
Jan 5, 2017 09:27 PM
RKSmith163
Mar 28, 2016 10:40 AM
Evanu1987
Dec 12, 2015 04:31 PM
nastystang03
May 3, 2011 08:53 PM
