No crank, no start
Old Feb 5, 2021 | 03:56 PM
H2Donkeykong's Avatar
Default No crank, no start
Hi. I have a 2005 Hummer H2 , went to the store, came out turn the key nothing, passlock light went out,Battery is full, towed it home sat for two days turn the key to on then to accessory can hear a slow thunk thunk thunk, key wont turn off, key is stuck in accessory position and and cant shift out of park with key in the on position and battery is now dead.
so what a bad ignition switch?
Old Feb 5, 2021 | 06:31 PM
Bad ignition switch, maybe a bad ground somewhere, maybe a bad battery.
Old Feb 5, 2021 | 07:40 PM
Start with the basic, take your battery to an auto parts store and have charged/tested for free, be prepared to buy a new battery.
Old Feb 5, 2021 | 11:05 PM
does your cluster actually show you are in park?
reason i ask is because the shift cable bushing on the transmission end goes bad leaving the transmission in whatever gear it popped off at. not in park no key. another probable cause can be the shifter wiring in the center console. the wires tend to break from moving the shifter also causing to not release the key. both very common issues with the H2.
Old Feb 6, 2021 | 01:28 PM
Ive learned with gm when the battery is dead you cant get the key out so there's that. Battery is good.
Old Feb 6, 2021 | 07:57 PM
Battery age & test results?
Old Feb 7, 2021 | 08:03 PM
RoH2's Avatar
I had a similar situation, except I could remove key.
Turned out my starter was toast. Replaced and cranks/starts no problem.
esfop319
Dec 3, 2019 03:53 PM
stoneman
May 7, 2018 01:41 PM
djslickrick
Nov 10, 2011 09:21 AM
taz7593
Nov 18, 2008 02:01 PM
lwolny
Sep 16, 2007 04:03 PM
