New 3 months old battery dies again
Old Mar 24, 2016 | 08:43 PM
yrkdmaxh2's Avatar
Originally Posted by H2Miami
Im hoping the same . Also this little cheap china volts sucker use some type of resistance to heat the chemical
For some reason it may gets shorter cause a few time I touched and feels hot . Not to burn but little over warm . Also it got an Led which stay on all the time
My only doubt is if this could be enough discharge a battery overnight
Well .will Keep an eye
Only one way to find out
You never know. If it uses resistance heat and is that warm it may be drawing a couple of amps of current which may be enough to drain down your battery.
Old Mar 27, 2016 | 12:19 PM
H2Miami's Avatar
Problem was the battery . Even though it get charge and hold it for a day battery was death after a night
Autoparts replaced under warranty
So far no more problems
Once warranty expired I will get another brand
Autocraft will not see my $ again . 3 battery in 2 years . Always same problem
Old Mar 29, 2016 | 09:40 PM
yrkdmaxh2's Avatar
Good deal!
Old Apr 8, 2016 | 01:16 PM
Wfive's Avatar
I had same issue draining and damaging 3 batteries in 30 days. My electrical mechanic found it was a damaged ABS sensor wire that was shorting out causing computer to run and drain battery...ABS/TC lights were on. I was about to send module in to repair. No need ones short was fixed... Hope this helps.
Old Feb 29, 2020 | 03:53 PM
MeAndMy3's Avatar
My 2006 H3 dies after a single day of not driving it. The dealer told me the control module was bad. Replaced it for around $800. One month later it they replaced the battery. Another $440. Still dying. Are there any suggestion that may cure this problem?
Old Feb 29, 2020 | 04:44 PM
Old Mar 3, 2020 | 05:02 PM
oceanbrave's Avatar
For all those battery questions do yourself a big favor and
get one of these get one of these
They are smart instruments that calculate the charge state, health %, CCA etc all in a matter of seconds
Its not a "dumb" multimeter that simply measures voltage, but a smart computer that takes small micro-current samples to calculate the internal resistance of the cells and uses math to match well known parameters and analyse the state of the battery.
I'm not a salesman, just an electronics engineer, and one of these will simply take out all the guesswork concerning the state of your battery!
Plus they are cheap!
miltonluban
Nov 15, 2013 04:30 PM
miltonluban
Nov 14, 2013 01:12 PM
Tech5
Mar 17, 2011 10:32 AM
liuya298717
Sep 7, 2010 06:19 AM
nascar 17
Jul 10, 2006 12:33 AM
