Need help / measurement from someone with a stock H2
Old Sep 13, 2018 | 03:55 PM
Mr. Demeanor's Avatar
Default Need help / measurement from someone with a stock H2
Truck is in another shop still having problems getting correct ride height after lift installed.
Can someone measure the distance from the center of the rear axle/hub to the bottom of the black trim around the wheel well. Measure straight up.
Thanks in advance.
Old Sep 14, 2018 | 07:49 AM
calif phil's Avatar
25 1/2"
Old Sep 14, 2018 | 10:36 AM
Thank you!
Old Sep 14, 2018 | 01:47 PM
GM has a couple of specific size blocks they put in between the axle and frame when calibrating to be perfectly level it but they are not needed. You just have to block the rear up in some way to make sure its at the correct height and is level. I have a Tech 2 and I just used a couple of jacks under the rear of the frame, got it perfectly level and at the right height, then did the calibration which sets that particular height and level as the reference.
Synthetickiller
Nov 11, 2016 06:16 PM
Synthetickiller
Aug 15, 2015 03:12 PM
jsbihn
Apr 17, 2014 03:44 AM
RickStang
Mar 1, 2014 05:25 PM
H2CANEPADESIGN
Oct 25, 2013 11:51 AM
