Maplight cover
Old Jul 31, 2024 | 08:04 PM
pktavana87's Avatar
Default Maplight cover
How do I remove the cover on the maplights on the headliner. I can't find anything on this.
Old Aug 1, 2024 | 07:19 PM
Mark R's Avatar
Originally Posted by pktavana87
How do I remove the cover on the map lights on the headliner. I can't find anything on this.
Well we got some experts here. it would help if you post the year of your H2. Also on my 09 I have Map Lights front and rear. I assume your asking about the Front.
Old Aug 1, 2024 | 07:38 PM
pktavana87's Avatar
2008 and front ones
Old Aug 1, 2024 | 07:47 PM
Mark R's Avatar
2008 and front ones
Cool...don't have the shop manual in front of me...but I'm sure a few guys will pop on with the answer. I just went out and looked at my 09 front. It's the same as the rear lens.
Look at the on off button... towards the rear of the lens (Towards You) there is a very small slot cut into the lens. If you stick a small flat blade screw driver in that slot... you should be able to pop it lose exposing the Lamp.
Old Aug 2, 2024 | 07:07 AM
pktavana87's Avatar
I need to remove the cover, There is a water leak above it.
Old Aug 2, 2024 | 09:12 AM
Mark R's Avatar
DooooooooooooooooH!!! Infamous [size=21px] HUMMER H2 Water Leak... They all leak. And in several places. You should do a search here and see how many threads there are on Water Leaks and the area's and the Fix's. Lots of good info on fixing the H2 Mobile In Cabin Mobile Shower.[/size]
Old Aug 2, 2024 | 09:45 AM
pktavana87's Avatar
I saw the treads, but I am still trying to find out how to take the cover off the map light area.
Old Aug 2, 2024 | 03:19 PM
Mark R's Avatar
Again: Look at the on off button... towards the rear of the lens (Towards You) there is a very small slot cut into the lens. If you stick a small flat blade screw driver in that slot... you should be able to pop it lose exposing the Lamp.
You need a tiny small screw driver. You stick the flat blade in that little slot and try to pop it out.
Kdog
Dec 24, 2011 04:19 PM
ozark1
Aug 31, 2011 08:46 AM
davyo
May 20, 2010 03:50 PM
madmike
Mar 2, 2009 09:15 PM
crank
Jul 18, 2007 08:56 PM
