Low Oil Pressure - Replaced O ring, sending unit (no screen) and oil pump
Old May 4, 2022 | 01:05 AM
H2 Lake City's Avatar
Default Low Oil Pressure - Replaced O ring, sending unit (no screen) and oil pump
2004 H2 -220k
oil pressures has always been at 40psi
now about 10 on start and after a few miles down to 5. Higher rpms will increases to about 10 but then fall to almost 0 at idle. Only other symptom a very faint clicking and stutter or hesitation at idle. She runs fine up and down the Colorado passes - still has plenty of power.
Oil pressure reads within specs manually.
Trying to solve this - replaced O Ring, Replaced Sending Unit (no screen), replaced oil pump, replaced timing chain since I was there. No change in symptoms.
cleaned fuel injectors (2 had bad spray pattern), replaced nasty knok (spelling) sensor, new spark plus & wires. I had the shop check lifters - 2 different shops say they are fine. Of course I have changed the oil several times - no visible gunk or shiny stuff at the end of the drain.
so lots of work and I still have same symptoms. There is definitely something wrong - you can tell at idle. Throws no codes.
Any ideas on what I should try next?
Old May 4, 2022 | 07:58 AM
calif phil's Avatar
You need to screw in a mechanical oil pressure gauge and get an accurate reading, your dash oil pressure gauge could be giving an erroneous reading.
Old May 4, 2022 | 08:26 AM
tharber's Avatar
My guess is unfortunately cam bearings......
Tim
Old May 4, 2022 | 09:08 AM
If a scan tool is showing the pressure is correct then I'd assume some electrical connection or potentially the motors in the cluster are failing which is somewhat common.
Old May 5, 2022 | 02:57 PM
fastNYsix's Avatar
Could be a cam bearing walked. When I pulled the cam on the lq4 I installed in my gbody, cam bearing #2 fell out. The cam wasn't damaged and neither was the block bore. I put new bearings in and was good to go.
Rick L'Esperance
Sep 5, 2020 04:54 PM
Joeybiff
Jan 10, 2019 03:34 PM
H2Miami
Dec 3, 2018 05:20 PM
ferraribuyer
Mar 27, 2017 09:04 AM
DanH3
Jul 11, 2014 08:15 AM
