Looking for some part numbers
Old Dec 6, 2020 | 03:44 PM
Daniel Z's Avatar
Default Looking for some part numbers
looking for part numbers or links would work, thanks in advance.
1. Fuel/Injector line - time to replace the old rust line. Not sure if the plastic round lines need to be replaced, but definitely the line going across. May also replace the fuel injectors themselves.
2. Fuel tank/cover bolt 🔩 its a special bolt
3. Is replacing the head gasket a huge task and does it require any special tools? I definitely need a torque wrench.
misfire cylinder 8, already replaced wires and coils. Also, recommend anything else to get done while replacing the gaskets?
Thanks.
Old Dec 6, 2020 | 06:49 PM
most of your queries require the year on your truck. even if you where asking at an auto parts they would ask the same.
Old Dec 6, 2020 | 07:38 PM
Thanks.
No need for part numbers!
1-Replace the steel fuel lines with nylon.
2-Nothing special with the bolt.
3-Only a cylinder 8 misfire?=fuel induction cleaning.
Old Dec 7, 2020 | 12:48 AM
Daniel Z's Avatar
2005 H2
austinwae
Hummer H2 SUT
Feb 18, 2024 03:43 AM
Daniel Z
Sep 4, 2020 07:47 AM
EliteAutoGroup
Oct 26, 2018 04:33 PM
jakeys1999
Apr 13, 2018 08:51 AM
dscaberboy
Oct 8, 2007 04:52 PM
