Leaking roof help
Old Jul 23, 2020 | 07:18 PM
Rogerb's Avatar
Default Leaking roof help
The roof is leaking on the front and rear headliner and around the sun visor bracket, driver side pillar, any ideas where the leaks could be coming from?
Rear cargo area
Driver side headliner
sun visor bracket
Old Jul 23, 2020 | 07:32 PM
Just keep an eye on the weather, if you see rain in the forecast, park in the garage, and don't forget to avoid car washes too.
Old Jul 23, 2020 | 07:47 PM
it could be the roof light gaskets or electrical plugs under the roof lights.
Old Jul 27, 2020 | 08:25 PM
Danthyman69's Avatar
Default I had a similar leak.
Mine was sunroof drain. The hose popped right off the drain and was just leaking water into headliner instead. Also had one of the rear roof lights leak.
Old Jul 28, 2020 | 05:20 PM
Chrmer3's Avatar
Search the forums - this is something every h2 owner has gone through. When you start correcting the issues and see how Hummer designed it originally (lol) you will understand why they all at one point leak. It can be corrected just take your time and seal all the areas mentioned in the posts. Start at the clearance lights (new gaskets can be had on eBay). Also the top front drains above the doors (diverted by rubber seals).
Old Aug 3, 2020 | 04:07 PM
Dave in Maine's Avatar
Corner and marker lights are generally the cause, especially if you've already had the sunroof drains blown out and checked, like I did. In my case, it was the driver side front corner light,
RambosH2
Oct 17, 2019 11:48 AM
yanivf
Feb 18, 2019 10:49 PM
dontheo55
Mar 28, 2017 04:14 PM
RenegadeMicro
17
Mar 24, 2012 12:54 PM
Firepilot2
Jul 19, 2011 06:32 PM
