Leak from rain into cargo area
Old Nov 16, 2006 | 12:52 PM
tls 14's Avatar
Default Leak from rain into cargo area
Is anyone else having issues with rain leaking into the cargo area from windows or somewhere on the sides?
Old Nov 16, 2006 | 03:14 PM
Sugardaddy's Avatar
Default RE: Leak from rain into cargo area
Only if I forget to roll up the windows.[8D]
Old Nov 16, 2006 | 05:46 PM
dilo2001gt's Avatar
ONLY IF I DO THIS
[IMG]local://upfiles/111/FAB0E2860D9D4AF0B848DA444695D295.jpg[/IMG]
Old Nov 16, 2006 | 05:49 PM
dilo2001gt's Avatar
OR THIS
[IMG]local://upfiles/111/D45FC29413E4453AAFF2B72F090868A0.jpg[/IMG]
Old Nov 16, 2006 | 08:39 PM
blackstangs281's Avatar
Are you talking H2 or H3? Might get you more help.Name:  wink.gif
Old Nov 16, 2006 | 09:29 PM
Dennis's Avatar
He's gotta be talking about a Land Rover..[:@]
Old Nov 17, 2006 | 10:22 AM
Sugardaddy's Avatar
ORIGINAL: Dennis
Or a Jeep!
Old May 10, 2023 | 03:53 AM
Parabellum8086's Avatar
Exclamation
Wow!
I can't believe no one else has the same issue that you and I have here!
I just purchased a 2007 Base model H3, and boy, am I having leak issues!!!
First, it was the sunroof drain lines (BOTH OF THEM!!!) After I thought it was taken care of, I began to install an aftermarket stereo system (2 amps, a crossover, and 13 speakers). I soon realized that before I began, I was going to have to pull my carpet out and replace all of the old underlayment.
It was SATURATED!!!
Soon after getting down to bare metal (I removed damn-near every piece of plastic from inside that you could imagine), I discovered that water was STILL managing to find its way in from somewhere on the passenger side!!!
So, I took my water hose, laid it on top of the roof, and got inside of the vehicle and closed the door. I then looked around the top edge of the passenger's side very carefully, and there it was:
At the top, in the very back of the vehicle above the far back right-side window, water was coming in through an ENORMOUS crack underneath the track/rail on the roof!!!
Apparently, the manufacture (or a PO) used some sort of seam sealer or bondo to seal a gaping hole underneath the track/rail.
OMG, the amount of water that is underneath the rubber floor mat in the back cargo area...
What the f#@& was GM thinking whenever they designed this vehicle?
Why didn't their fabricators WELD the two pieces of metal together instead?
I'm left scratching my head...
For now, I used Flex-Seal (the spray AND the tape). I removed the track/rail, and sprayed a generous amount (about a half of a can) onto the hole, and along the entire length of the seam. Inside, I used the spray, then the tape, then some more spray.
New underlayment is here. Just waiting until the coast is clear before I start putting new material down.
For now, I just want my music, and to be able to actually enjoy riding around in my 'new' vehicle. I'll remove my amps & crossover later, and rip out the old underlayment from the back cargo area as well.
I'm afraid to even remove the driver-side track/rail, in fear of opening up a Pandora's Box...
Old May 10, 2023 | 01:47 PM
i wonder how long it will take for the flex seal to fail or tear from all the bass hammering at the seams.
Old May 10, 2023 | 02:54 PM
Don't believe everything you see on tv & online!
