Knock Sensor...
Old Apr 21, 2024 | 09:02 PM
Mark R's Avatar
Default Knock Sensor...
My 09 H2 just thru a Knock sensor code. Any one have a Pic of where it's loctaed or explain how hard or easy it is to get to? I'm sure you have to drop the front Bash Pan... If that's the case Fa-Gat_About_it. I know it's a one bolt deal wth a 2 conductor plug but don't feel like getting down and dirty in this crappy weather.
I'll due a search now and see what I can Find.
Tanks
Ok just did a search and found info on the 05 H2... Does the install require pulling the Intake????!!!!!! Gheez I hope not. So are two required?
Old Apr 22, 2024 | 09:42 AM
NUMBER 9
NUMBER 14
Old Apr 22, 2024 | 10:10 AM
Gavin Costigan's Avatar
number 15 not 14
Old Apr 22, 2024 | 11:07 AM
Mark R's Avatar
Originally Posted by Gavin Costigan
number 15 not 14
Thanks Gavin.... I was Chit-en Bricks untill I found my service manual and looked it up by DTC .. Then right to the page that you posted. Thank You!!
Man.. the owners of the earlier H2's I feel sorry for. Ripping the intake off was not a good design for the 6.0 or I guess earlier 6.2's. Wonder when the light bulb went off at GM and they moved and redesigned the sensor and location. So I guess the 08 and 09-2's are on the outside block. Not sure of the different model year Sensor changes.
Anyway..thanks for taking the time to look that up and post the pic's. I know that some work.
Old Apr 22, 2024 | 12:05 PM
number 15 not 14
Odd... Mitchel on demand has it stated at number 14. thats where i got the pictures from.
Old Apr 22, 2024 | 03:11 PM
legerwn's Avatar
I've had mine off when adding goodies the engine, #9 & #15, single bolt through the center with plug.
Neal
Old Apr 22, 2024 | 06:17 PM
Knock sensors are mounted in the block.
Old Apr 23, 2024 | 12:19 PM
Yeah that’s weird. Number 14 looks like it’s pointing at an ignition coil or something
Old Apr 23, 2024 | 04:45 PM
Mark R's Avatar
Yes they are... But if you had payed attention you would know that the Newr design 6.0 motors have them outside the block on each side.. Didn't your Drill Seargent explain Left foot Right foot first? ...LMAO
Old Apr 23, 2024 | 05:30 PM
Both mounted in the block not mounted on a valve cover.
