Installing Double DIN NAV w/Backup Camera - ?'s
Hello All,
This is my first post as I recently purchased a 2003 H2 and just completed a bunch of deferred maintenance (oil changes, tires, ball joints) prior to tackling the sound system replacement. I believe I have the premium sound system as I have the 6 speakers and 2 tweeters in the front pillars? I haven't yet disassembled the center console to check the amp model as I am wiring the RP5-GM11 to the Jensen wiring harness.
I am installing a Jensen VX7020 with a PAC RP5-GM11 interface kit to retain the steering wheel controls. I am also installing a backup camera and I have both the video wire for a wired installation and a wireless transmitter receiver for a wireless install. I would appreciate knowing if others have had good experience with the wireless option and where they mounted the transmitter/receiver for best signal? For those who went the wired route how you routed the camera wires?
Also, if I read the manual correctly there is already a Nav antenna on the roof over the front passenger seat? If so can I connect the new Nav Radio into that antenna or must I use the antenna that came with the unit?
Thanks in advance!
Thanks in advance!
4u33er
05-20-2013 08:16 PM
ak47dennis
10-21-2012 09:11 AM
ak47dennis
08-28-2012 01:10 PM
BirchH3
05-31-2007 01:32 PM
