Idiot sprays brake-clean on steering wheel badge…
Old Aug 15, 2022 | 03:02 PM
2004H2's Avatar
Default Idiot sprays brake-clean on steering wheel badge…
Had my truck back at transmission shop, for shifter issue, went to get it and it was late and didn’t notice it….they said they cleaned it up after driving it thru some muddy road…truck was washed and vacuumed….needless to say they said, IDK who did that….
Anyone know where i can get a replacement badge for 2004 H2 ?
does anyone know how to remove the horn button wrap on steering wheel ?
did a whelen 100 watt pa speaker/horn installed today, just what I needed for theese inept drivers in Broward county…
definitely could hear the horn now, and talk on 100 W PA system….if they **** me off…lol
2004H2
2006 H3
Old Aug 15, 2022 | 05:32 PM
That was never available from GM as a separate part number, only as the entire airbag.....
I do have one of the prior style airbags in black I'd sell for probably $75. The original style had a molded in logo instead of a stuck on emblem.
There is an aftermarket badge on eBay for $40.... https://www.ebay.com/itm/294084874255
Or search Hummer H2 airbag. You can find both styles available for about $130.
Old Aug 15, 2022 | 06:36 PM
2006 H3
Replace it, whatever the cost, they pay for it.
Old Aug 17, 2022 | 06:19 PM
oceanbrave's Avatar
does anyone know how to remove the horn button wrap on steering wheel ? - see note below ->
2004H2
2006 H3
Search for "Hummer H2 2005 - Horn Issues" on YT ffwd to the 2min mark.
Old Aug 18, 2022 | 09:58 AM
2004H2's Avatar
Thank you….for the info…
I don’t think im going to let them touch it, ill fix it, so far this transmission shop has been a Nightmare….
Old Aug 18, 2022 | 02:24 PM
Ouch - yeah that is melted to the point of being unrepairable. Cheapest option would be to grab one of those aftermarket ones and swap it out. The airbag is actually very easy to remove from the steering wheel. Couple of openings on the backside that you jam a flathead screwdriver into to push a couple of metal retainers away from the two metal posts to release it.
Old Aug 19, 2022 | 01:43 PM
Gavin Costigan's Avatar
Please be extremely careful when removing the airbag. Be sure to disconnect the battery and even so, keep your face out of the line of fire when you do it.
Old Aug 19, 2022 | 01:58 PM
tharber's Avatar
https://www.ebay.com/itm/29408487425...hoCiZkQAvD_BwE
Google search Hummer H2 steering wheel emblem.
Tim
Old Aug 19, 2022 | 04:21 PM
oceanbrave's Avatar
Indeed disconnect the battery and proceed carefully as @Gavin Costigan has pointed out, remember there is an explosive charge inside !
Old Aug 21, 2022 | 09:23 AM
2004H2's Avatar
Default 👍👍👍
Originally Posted by gavin costigan
please be extremely careful when removing the airbag. Be sure to disconnect the battery and even so, keep your face out of the line of fire when you do it.
oceanbrave
Dec 31, 2020 11:33 PM
Fish On!
Aug 27, 2019 11:59 PM
choochmalooch
May 25, 2018 06:53 AM
nicolen78
Jun 30, 2009 07:00 PM
hewshum
Jan 6, 2007 08:16 PM
