I am looking for a tire swing latch that goes on the truck
Old Sep 3, 2011 | 11:57 AM
afghan2006's Avatar
Default I am looking for a tire swing latch that goes on the truck
Hello my fellow Hummer friends. I bought a tire swing and mount from craiglist and got screwed over by a guy telling me that the latch was cheap and you can get it anywhere, so if anyone has one or knows where i can find one, please let me know. I need the latch that goes on the truck that the swing latches close onto. In the picture, i need the part on the bottom left. Thank you!
Attached Thumbnails I am looking for a tire swing latch that goes on the truck-941bdd4d716d.jpg
Old Sep 3, 2011 | 02:37 PM
fyr145's Avatar
Sorry some jerk took advantage of you.... I have the complete exterior spare tire set that I just removed. I have that part on the bottom left that you are looking for. Its part # 25864506 and it lists at a dealer between $400 and $600. I would let go of mine for you for $400 plus shipping. I dont know where you live so I could calculate the shipping costs.
Old Sep 3, 2011 | 02:49 PM
afghan2006's Avatar
Ya I the dealer is really overpriced for this part, I was trying to stay away from spending that much, thanks for the offer though.
Old Sep 3, 2011 | 02:55 PM
fyr145's Avatar
Sorry I couldnt help...........
Just out of curiosity, what were you looking to spend?
Old Sep 3, 2011 | 10:10 PM
zhummer's Avatar
From the dealer you are looking at over $600.00 for the latch as you probably already know. I have a take off one in excellent condition, would be $170.00 shipped UPS ground
Old Sep 5, 2011 | 01:12 PM
afghan2006's Avatar
email me your contact info so we can get in touch zabejamshidi@hotmail.com
Old Sep 5, 2011 | 11:50 PM
fyr145's Avatar
Question Were you talking to me or zHummer??
email sent (if you were directing your post to me).
Old Sep 7, 2011 | 07:34 PM
zhummer's Avatar
Email sent as well
Old Feb 16, 2020 | 01:05 PM
Andreas Pylarinos's Avatar
Default #25864506
Just checking to see if this part of the hummer tire swing gate latch is still available?
Old Feb 17, 2020 | 08:25 AM
oceanbrave's Avatar
Not sure what's wrong with your old latch (rust maybe?) have you considered re-conditioning your old one? It cost me a few buck to make it like new.
I completely dismantled the latch (and the whole carrier) and got the top-lever shot-blasted and powder-coated. I also carefully removed the V-Shaped rubber insert and got the casting blasted and powder-coated and glued the rubber back in.
The trickiest part was the steel pin holding the spring mechanism inside the top-lever. As the pin was "pressed" in the factory I filed this end flat to free the pin then drilled and tapped. You can see the small button-head SS screw (slightly bigger than the diameter) you'd never know.
The picture above shows the pin (RH) after filing, the zip-ties kept the pressure off the pin.
After all the re-work was done everything looked brand new!
Took these today after 2 years of English rain, I figure a brand new one would look the same!
