Hummer Won't Start - Battery & Alternator are Good
Old Nov 30, 2019 | 06:28 PM
hummer_on_fumes's Avatar
Default Hummer Won't Start - Battery & Alternator are Good
Hello all! Had a sluggish start problem with my 04 H2 recently. Bought a brand new battery in October after they tested it and it was bad. They also tested the alternator and said it was good. Today the Hummer is dead when I went to start it, it would make a click noise and everything electronic would get power, but it doesn't try to start at all. I took the battery out and went back to the battery store, they tested it and the battery is fine. Anyone know what I should try next? I'm not a mechanic or even close but I've been able to fix a lot of things on the H2 by myself over the years. Any advice on where to start would be greatly appreciated! Starter? Ignition switch? Help please!
Old Nov 30, 2019 | 06:39 PM
Clean connections at the starter motor.
Old Dec 1, 2019 | 03:54 PM
Check starter relay as well and also check grounds to make sure the grounds to the engine and frame are good.
Old Dec 2, 2019 | 07:48 AM
calif phil's Avatar
Try tapping on the starter solenoid with a small hammer while you have someone try to start the truck from the inside. If it cranks then you know the starter is bad. It's not a definitive test but it's a quick easy thing to try.
Old Dec 2, 2019 | 06:50 PM
I took the old starter off because it's rusted to hell and I'm pretty sure it's the problem. With the worst luck imaginable when I was taking one of the nuts off it fell and I can't find it anywhere. I even checked the ground all over with a magnet. The only thing I can think of happening is that it fell inside here (attached photo). Will it cause catastrophic damage if I start the truck with a nut inside there ? Is that the flywheel? I did order a boroscope and I'm going to try to look inside there to see if I can see the nut.
Old Dec 2, 2019 | 07:57 PM
Just to be clear, you took the nuts off after you unbolted the starter? Btw, that's the tc and flywheel. You can use a socket on the crankshaft to turn those, or get a flexible stick magnet to find your nut.
Old Dec 2, 2019 | 08:18 PM
Yeah i unbolted the starter first because the wiring attached on top was too difficult to get to until I had it loose. Then in the process of taking the nut off to disconnect the battery from it, it dropped somewhere and I've searched and searched and cannot find it. I will try using a flexible magnet and boroscope to find the nut. If I can't find it but it really is in there, will it cause damage to run the truck ?
Old Dec 2, 2019 | 09:55 PM
try looking from the top of the engine down maybe its on the motor mount or chassis /suspension or pinched. on the exhaust shields if you still have any
Old Dec 5, 2019 | 02:09 PM
I've looked every where, even using a magnet and boroscope and cannot find the missing nut. I guess my main question is that if it did somehow get into the transfer case opening where the starter was removed, will it cause any damage if I run the truck with it in there? I love creating new problems before I even fix the original one!!!!!!!
Old Dec 5, 2019 | 10:39 PM
well there is an inspection window on the bottom of the transmission you might have access to reach it. anything is possible having a loose part next to a rotating mass.
