Hummer down HELP
Old Jan 30, 2026 | 01:50 PM
EPT_H2's Avatar
Default Hummer down HELP
Well I’ve been trying to figure out this problem with my hummer.
The rig drives perfect straight and reverse. Only when I I’m turning it feeling like I have a dragging rear differential the turning radius is god awful.
03 hummer adventure
240k
Kryptonite front suspension
heads
cam
long tube headers
rebuilt transmission
new cv axles
this happened before the front suspension upgrade due to the planetary gear failing on me. Now I haven’t driven the hummer in about six months because I don’t want this to happen again because it does feel like it’s pushing against each other when I turn. again, the turning radius is really really bad but when I go in reverse or forward, the truck doesn’t work. It’s only when I turn. Any help please I wanna drive my truck again
Old Jan 31, 2026 | 08:13 AM
legerwn's Avatar
it sounds like your truck may be stuck in 4 high lock,
when in normal 4 high you should not feel any resistance when turning
Neal
Old Jan 31, 2026 | 07:24 PM
Gavin Costigan's Avatar
Neal
yep sounds like it’s stuck. Pull the front drive shaft. If the truck drives at all with it out and the T case in 4 hi open then it’s stuck.
Old Feb 2, 2026 | 02:18 PM
RobertDez's Avatar
Probably needs a new shift encoder.....
MuricaMa
Oct 6, 2022 07:59 AM
stonewall
Jun 19, 2021 06:57 PM
armr
May 1, 2013 11:43 PM
chris4851
Sep 23, 2010 03:43 PM
wfturner
Sep 21, 2010 04:01 PM
