how to tell size lift ?
Old Oct 6, 2020 | 04:47 PM
Steven Eric Lambert's Avatar
Question how to tell size lift ?
This is my 3rd H2 - i lifted the 1st two myself. this i bought already lifted. i need to replace front shocks. can i just remove them ,measure and match ??
Old Oct 6, 2020 | 06:49 PM
You lifted 2 H2's by yourself, and need help measuring shocks?
Old Oct 7, 2020 | 08:27 AM
Hummerz - i bought complete kits for others(2")...this is one i got 4 years ago stored for most time and now want to get rid of but one corner has fallen - i dont know what was originally put on it other than its fab-tech and cheap. i figure since it has to be 5-6" it doesnt mater as a long as i buy 2 shocks. this is probably dumb question but do they make air bag suspension that tall ? my experience is just installing complete kits/ not much skill -
Old Oct 8, 2020 | 08:28 AM
Default Got it — torsion bolt - da
torsion only - I should have known
Old Oct 8, 2020 | 12:03 PM
I know this is going to sound elementary to most people.
If you know it's a Fabtech lift, go to the Fabtech website and see what shocks they use on their H2 lift kits.
Or go one step farther and call Fabtech and see what shocks they recommend and/or the collapsed and extended shock length.
Old Oct 8, 2020 | 12:09 PM
HOLY SHEET, that took a few minutes and I even took the time cut and paste all of the info!
Man, these people who need to be spoon fed everything. I blame the parents...
REAR: FTS7266 - DESCRIPTION PERFORMANCE TWIN TUBE SHOCKFabtech Performance Shocks have been designed to work in conjunction with each of our suspension systems, resulting in superior ride control. Features include high velocity 9-stage valving for excellent dampening capabilities and a closed cell insert to reduce shock fade at high speeds.
FEATURES
  • Twin Tube Hydraulic Construction
  • 9/16″ Hardened Chrome Piston Rod
  • 1 3/8" OD Piston
  • Closed Cell Foam insert
  • High Flow 9 Stage Valving
  • Extended Length – E32.95
  • Collasped Length – C18.92
  • Stroke Length – S14.03
  • Top Mount – EB1
  • Bottom Mount – EB1
FRONT: FTS7191 - DESCRIPTION PERFORMANCE TWIN TUBE SHOCKFabtech Performance Shocks have been designed to work in conjunction with each of our suspension systems, resulting in superior ride control. Features include high velocity 9-stage valving for excellent dampening capabilities and a closed cell insert to reduce shock fade at high speeds.
FEATURES
  • 1 3/8" OD Piston
  • Extended Length – E21.69
  • Collasped Length – C13.16
  • Stroke Length – S8.53
  • Top Mount – S38
Old Oct 8, 2020 | 12:57 PM
Hummerz - i bought complete kits for others(2")...this is one i got 4 years ago stored for most time and now want to get rid of but one corner has fallen - i dont know what was originally put on it other than its fab-tech and cheap. i figure since it has to be 5-6" it doesnt mater as a long as i buy 2 shocks. -
Shocks don't control ride height.
TheBeast
Aug 31, 2020 03:23 PM
jntfj80
Jun 23, 2013 10:55 AM
JRSH2
May 4, 2007 08:35 PM
JRSH2
May 4, 2007 08:27 PM
JRSH2
May 4, 2007 08:26 PM
