how do I move an H2 with a dead battery?
Old Mar 14, 2009 | 03:51 PM
bonanza's Avatar
Default how do I move an H2 with a dead battery?
H2 is in the garage, grill against the wall, battery dead, can't open hood, it's against the wall. Is there a way to get it out of park with a dead battery?
Old Mar 14, 2009 | 05:24 PM
I'm pretty sure if you turn the key ON, you can shift it to neutral??
Old Mar 15, 2009 | 01:51 AM
madmike's Avatar
Banned
i agree. I believe the shifter is NOT electromechanical. Id try it out but im at work
Old Mar 22, 2009 | 11:55 AM
With the battery dead you can't put the tranny in nuetral. There is a disconnect switch under the console. Been awhile but you have to remove either the console bucket or trim cover and you can push the disconnect which will allow you to shift into neutral. Seems like there is a thread on this. try the search function.
Old Mar 22, 2009 | 08:44 PM
Says YOU.................
Old Mar 26, 2009 | 01:30 AM
Carcrazy's Avatar
Banned
think positive, you can easily move it by simply put it on a neutral mode then if it takes you a little bit hard, try to gather a manpower for help.
Old Sep 28, 2018 | 12:34 AM
Apqpleansigmambb's Avatar
Default Dead battery, unlock gear shifter to get in neutral.
Information worked great thanks!
just remove center console glove box 4 screws, long handled straight tool, touch botto right side of shifter handle mechanism push it towards drivers side, this releases locked shifter and you can adjust to any position, takes under 5 minutes to complete.
Old Sep 28, 2018 | 06:44 AM
choochmalooch's Avatar
And yet another 10 yr old thread is resurrected for our viewing pleasure.....
Old Sep 28, 2018 | 09:46 AM
Old Feb 19, 2022 | 01:53 PM
H2&M109A3Owner's Avatar
Default Agreed
If you have a good working H2 then it will not go in to neutral I had a dead battery and I could not manually turn the key and do this .
