how do I move an H2 with a dead battery?
With the battery dead you can't put the tranny in nuetral. There is a disconnect switch under the console. Been awhile but you have to remove either the console bucket or trim cover and you can push the disconnect which will allow you to shift into neutral. Seems like there is a thread on this. try the search function.
Says YOU.................
Information worked great thanks!
just remove center console glove box 4 screws, long handled straight tool, touch botto right side of shifter handle mechanism push it towards drivers side, this releases locked shifter and you can adjust to any position, takes under 5 minutes to complete.
