Hood open / Wiper motor issues
Old Dec 10, 2025 | 06:03 PM
OBIrishman's Avatar
Default Hood open / Wiper motor issues
Hello all,
2008 H2
I have a tricky one here. Had the truck sitting for a few months just cause I was riding my bike to work and used the wifes car. I was tired of chasing a parasitic draw so I installed a simple battery disconnect to just the fuse box. Started driving her again cause it was getting cold out. Now I have an "open hood" alarm. At the same time or coincidence, the front wipers do not work.
Notes:
I replaced the hood latch and still have the open hood alarm
Wiper fuse is good
When I turn on the wiper fluid button, fluid comes out but no wipers.
I did not check voltage at the motor when the switch is on yet
Every other feature on the wiper switch handle works. hi beams etc.
Took the front covers off to see if the wiper assembly broke from the motor and everything is intact
Thank you everyone
Danny
Old Dec 11, 2025 | 09:30 AM
a bad wiper motor Pulse Board Module driver board can cause parasitic battery draws. maybe that is two of your issues. battery drain and no wipers.
i am not sure if a Cardone Select 81-1046PB module would work as a replacement
Old Dec 12, 2025 | 10:45 AM
SHOCKTROOP40's Avatar
Good thread. My 09 H2 has been sitting for about a month now. I'd better check mine out now.
Old Dec 12, 2025 | 01:10 PM
OBIrishman's Avatar
Very interesting, I will try it out. The draw iv had for years and just got annoying to put a disconnect in recently.
Thank you
Danny
NW94Z
May 16, 2025 05:09 PM
dips
Jul 17, 2022 05:30 PM
2004H2
Feb 10, 2012 08:29 AM
hectour
Aug 3, 2011 06:41 PM
HummerMike
Feb 28, 2007 08:18 PM
