HELP! Stereo Q's
Old May 25, 2011 | 02:46 PM
Hitmannactual's Avatar
Default HELP! Stereo Q's
I have an 06 H2 with Bose premium sound. Touch screen nav single disk changer.
Today I started up and the stereo displays the clock for several seconds and shuts down. No other buttons besides power are responsive.
The cd motor is working and checking the disk and the screen displays the clock in lower right corner (as if the unit is turned off when driving) but no other functions.
Any ideas??
Old May 26, 2011 | 01:06 PM
Default hopefully resolved...
I read on several posts about disconnecting the battery and letting the computer reset itself. I did that and it worked. one word of caution, as you are disconnecting the bat leads, the fluctuation in current causes the passlock to kick in - disabling the engine, preventing the key from being removed from ignition among other things. Be aware, time with the bat disconnected will fix both issues. if anything else arises, ill post!
Old May 31, 2011 | 01:10 PM
Gleamor's Avatar
My 03 had the same issue with the factory unit, I was able to reset it using the previously indicated method once, but it happened a second time and that was its last breath.
Pioneer AVIC-Z130BT now and couldnt be happier.
Devilzer
Dec 11, 2009 06:31 PM
SMITTY865
Nov 8, 2009 01:21 PM
lilred
Oct 22, 2009 10:16 PM
Alukavi
Mar 19, 2009 07:20 AM
hummerman62040
May 6, 2007 01:55 PM
