Help Please!
Old Nov 30, 2023 | 05:11 PM
Donpedro's Avatar
Default Help Please!
Hey Guy’s I’ve got a 06 H2 and this just happened! Anyone know if the vehicle is safe to drive like this and how I may go about fixing it? Thanks in advance!
File Type: mov
Old Nov 30, 2023 | 07:48 PM
Old Dec 1, 2023 | 10:19 AM
Gavin Costigan's Avatar
Nope! Absolutely not. Wouldn't even drive it around the parking lot. I hope your ebrake's in good shape. Looks like the brake line just got pinched in the suspension. Simple fix at least. find a brake line, and install it and bleed the brakes. Your local parts store probably has a brake line.
Amazon Amazon
This tool should help you remove the flare nut on the brake line without stripping it. Don't use an open end wrench.
Im not really sure if that line looks pinch or is just worn from age. If they've never been replaced before I'd recommend replacing all 6 (front, rear, and axle) they usually will fail all at the same time or very close to each other.
Old Dec 1, 2023 | 10:20 AM
What does the repo reaper have to do with this hummerz?
Xamer
May 14, 2012 11:36 AM
HarryBoy
Oct 24, 2010 11:12 PM
pumbak
Dec 22, 2007 07:34 PM
libyanhummer
May 21, 2007 01:27 PM
importkiller
Jul 8, 2006 12:08 PM
