- - Help Please!
(https://www.hummerforums.com/forum/hummer-h2-8/help-please-47579/)
Donpedro
11-30-2023 05:11 PM
Help Please!
1 Attachment(s)
Hey Guy’s I’ve got a 06 H2 and this just happened! Anyone know if the vehicle is safe to drive like this and how I may go about fixing it? Thanks in advance!
Nope! Absolutely not. Wouldn't even drive it around the parking lot. I hope your ebrake's in good shape. Looks like the brake line just got pinched in the suspension. Simple fix at least. find a brake line, and install it and bleed the brakes. Your local parts store probably has a brake line.
This tool should help you remove the flare nut on the brake line without stripping it. Don't use an open end wrench.
Im not really sure if that line looks pinch or is just worn from age. If they've never been replaced before I'd recommend replacing all 6 (front, rear, and axle) they usually will fail all at the same time or very close to each other.
