Help, no power to front wheels.
Old Dec 10, 2018 | 12:52 PM
KH2's Avatar
KH2
Angry Help, no power to front wheels.
Hi,
I picked up a 05 H2 last week. Yesterday we got 10 inches of snow, and well i do not have 4wd..
The buttons swing 4hi 4hi lock, 4low and the transfer case also switches. the rear diff also locks.
However i get no power to the front wheel.
regular mode, rear tires spin.
4hi lock rear tires spin
4lo lock rear tires spin.
Ive had the problem on my 2500 suburbans it was either the encoder thing on the front diff or a burned up transfercase, ( the 2500 have that auto trac crap with clutch packs)
Any one got any ideas ?
Shawn
Old Dec 10, 2018 | 11:37 PM
Blackbus's Avatar
Hi there. I’m going to point to your transfer case. The front diff on my 03 didn’t have any electronics to shift in and out of 4 wheel drive. The hummer is all wheel drive and always “locked in” the transfer case should be transferring the torque when the wheels are slipping.
Do you get any dummy lights when the front is stationary?
Old Dec 11, 2018 | 02:59 PM
KH2's Avatar
KH2
Well update I was showing how it doesn’t work and it stated last night Today same deal no power. So I stopped on a hill that has ice.
Regular 4Hi It spins at about 10 mph. Scrolls traction active. You can feel it doing something then it slowly sends power to the front
4lock and low lock it’s the same. Eventually kicks in. After trying it a few times it takes about 30-45 seconds for the front tires to work and it seems to have to be over 15-20 mph which makes no sense to me . Is there a speed sensor that could be bad?
No codes, no lights, etc. also I don’t get any “binding” on pavement in hi or lock
Old Dec 11, 2018 | 07:12 PM
2wheelmonster's Avatar
My 98 blazer did same thing and took it dealership and they said it happens until something breaks keep driving
Old Dec 14, 2018 | 11:17 PM
2003hummerH2's Avatar
Maybe the front diff is broken
Old Dec 29, 2018 | 04:35 PM
AdelRh2's Avatar
I read somewhere that it could be an electrical issue with a bunch of wires on the drivers side under the vehicle. The wires are most probably not connected to the frame which could cause the 4hi 4low and service 4wd message. It could be the transfer case but theres no harm in double checking those wires as well.
flyday58
Feb 15, 2016 01:39 PM
jbs45
33
Nov 26, 2014 12:15 PM
kwmamc
Apr 21, 2012 10:17 AM
racemx
Feb 20, 2009 08:58 AM
Chameleon
Feb 4, 2009 11:16 PM
