Help id this part
Old Apr 6, 2020 | 11:28 PM
Kavik001's Avatar
Default Help id this part
So this is under the drivers side just near the torsion bar key. I think maybe a brake porportioner or transfer case controller? The main problem is it is just hanging there by some of the lines with no mount or bracket and is heavy. Can anyone I'd and let me know how it is supposed to be mounted? Thanks
Old Apr 7, 2020 | 12:08 AM
it is your abs pump for your brakes. the lines holding it are your brake lines. you don't want it floating around. very dangerous.
Old Apr 7, 2020 | 06:04 AM
Kavik001's Avatar
Hows it supposed to be mounted? A bracket?
Old Apr 7, 2020 | 01:05 PM
available here ---->15064195
Old Apr 7, 2020 | 09:33 PM
Kavik001's Avatar
Also anyone have the bolt / nut part number for the bolt that attatches the torsion crossmember sides to the frame rail bushings? Had to take crossmember off to ket torsion bar out and stripped one of the screws..
Old Apr 8, 2020 | 08:58 AM
Kavik001's Avatar
This part isn't in stock anywhere. Anybody have a lead on one ? used is fine, I dont want to not secure this correctly
Old Apr 8, 2020 | 06:14 PM
there is someone parting out an H2 currently on the forum i think his name is drewandsteph
Old Apr 11, 2020 | 12:50 AM
Rusty_03's Avatar
The EVAP can should be on the other side of the frame. See that slotted hole in the frame? That’s where one of the bracket bolts go. I just pulled mine to replace the brake lines.
Keto88
New Member Area
Oct 19, 2019 07:36 AM
beitodesstrafe
100
Aug 3, 2011 05:44 PM
jdrew
23
May 4, 2008 10:00 AM
Golden Shellback
Jun 12, 2006 09:56 AM
MarkM
25
May 6, 2006 06:15 PM
