Help! Gonna go crazy with new H2
Old May 26, 2020 | 04:16 PM
Lilredtrk's Avatar
Default Help! Gonna go crazy with new H2
Hey y’all. I bought my hummer a couple months ago. Haven’t hardly even drive it. Decided to take it for a run up the gorge and bam! Everything started going haywire on the dash.
All these lights come on for no reason. Shuts the radio off. All the gauges drip to zero. The door locks quit working. Hit the T2 and all Come back up except the T2 and the ABS. Have brand new brakes all the way around too. Any advice?
Old May 26, 2020 | 04:38 PM
iwillnc's Avatar
Looks like battery is on its way out, get it tested.
Old May 27, 2020 | 07:57 AM
calif phil's Avatar
Loose battery cables? Check them real good. Check for water leaks, could have water intrusion to your fuse box.
Old May 27, 2020 | 04:05 PM
Also could be a bad ground under the driver side or at the engine block...
Old May 27, 2020 | 09:07 PM
Lilredtrk's Avatar
Brand new battery and hooked up tight.
Old May 27, 2020 | 09:08 PM
Lilredtrk's Avatar
Battery is new, I’ll check the fuse box next.
Old May 28, 2020 | 08:34 AM
Chrmer3's Avatar
If you didnt have the other anomailes- I would say wheel bearing (front hubs) that will give the ABS. T/C and brake warning lights. If you just had the brakes done, maybe someone didnt tuck the ABS wires back into position and one got cut, or possibly a bad front wheel bearing? Have someone connect it to a tech2 and they should be able to figure it out- Any GM garage or competent shop will have test equipment.
Chris
Lilredtrk
Jun 21, 2024 03:50 AM
H32006
Dec 6, 2019 07:15 PM
OceansEnd
Nov 14, 2019 08:06 AM
hollywood_x
18
Jul 11, 2017 09:44 PM
miltonluban
Aug 11, 2016 12:34 PM
