Help
Old Feb 20, 2023 | 08:14 PM
Hdog's Avatar
Default Help
My H2 is acting like it is skipping. The code say po300. I looked it up and it saying its a misfire. Could anything else cause this code to come up? Or what else should i check?
Old Feb 21, 2023 | 08:05 AM
calif phil's Avatar
Start with new plugs and wires and then report back.
Old Feb 21, 2023 | 09:53 AM
Hdog's Avatar
I checked the spark plugs even though they're not quite a year old. So I have bought a new set of coils for it last year. But I didn't throw away the old ones so I switched them back out to see what would happen and it's running fine now. I'm going to drive it a few more miles and see what happens. Hopefully this resolves my issue.
Thank you for your help
Old Nov 9, 2023 | 07:34 PM
LuvMy2006H2's Avatar
Hdog, I'm curious what happened with your P0300 mis-fire issue? Did the old coils actually fix it or did it come back shortly after? If it was the newer coils -what brand were they? I'm working on figuring out my own mis-fire and also collecting as much related info and everyone's different cause / solution they have found that worked in their case.
Old Nov 10, 2023 | 07:10 PM
Hdog's Avatar
Yes switching back to my old coils solved the problem. I haven't had any trouble since. If you buy new coils make sure you buy them locally. I didn't. They were supposed to be ACdelco but I think they were knockoffs.
Old Nov 10, 2023 | 07:56 PM
Well glad reinstalling the original worked. I was curious if the new ones were MSD. Yea a lot of knock offs out there in everything now days. Thanks for reply.
Old Nov 15, 2023 | 04:28 AM
Hdog's Avatar
No they were advertised as ACDelco coils. I found them on Amazon.
Old Nov 15, 2023 | 09:20 AM
zenith's Avatar
I purchased a set of MSD coil packs from Jegs around three years ago, paid around $600. Right at the one year mark two of them went bad, giving me the P0300 code on/off. Switched back to GM brand, haven't had an issue since.
Old Nov 15, 2023 | 09:22 AM
HellHoof's Avatar
I've bought a couple of "genuine ACDelco" items from Amazon before. They even had a holographic sticker on the package. Was NOT genuine ACDelco and crapped out within a short period of time.
fastNYsix
Feb 15, 2022 09:02 PM
ulthummer
Oct 11, 2021 11:23 AM
hummer_on_fumes
Jun 21, 2018 01:10 PM
agnt549
Mar 4, 2011 07:55 AM
ken haukaas
Jan 11, 2011 08:14 PM
