Heavy Duty rear hatch supports?
Old Nov 17, 2022 | 03:09 PM
zenith's Avatar
Default Heavy Duty rear hatch supports?
I've gone through 2 sets of rear lift supports for my rear hatch in over 2 years. Is there any such thing as heavy duty that will last more than a couple years especially in the winter? What a joke these all are. May have to figure out a way to transplant the Escalade electric rear lift, now that would be cool.
Old Nov 18, 2022 | 09:14 AM
Yes there are. There are a couple of threads on here that have part numbers for some heavy duty ones. I put some on mine a few years ago when I had dual rear ladders installed. Do a search and dig through some threads on here and you should find them.
Old Nov 18, 2022 | 10:26 AM
zenith's Avatar
Found several threads, this seems to be what I'm looking for. I don't have the weight of the extra ladders, but I did use the rubber with foil sound deadener on the inside and outside of the rear tailgate metal, lots of it, so there is a weight issue.
Not only that, I just hate crap that doesn't work.
Thanks again sir.
Old Dec 4, 2022 | 01:55 PM
Brunob00's Avatar
Gobi has several aftermarket options for the H2... they have a set of heavy duty gas shocks to be installed after you add their ladder... may do the trick...
https://www.gobiracks.com/product/re...ent-hummer-h2/
Old Dec 13, 2022 | 10:45 AM
zenith's Avatar
Thanks appreciate the info. I did install the lifts from liftdepot, so I'll see how those hold up this winter, so far so good.
Backporch73
Aug 21, 2018 10:46 AM
LoJac963
Jun 13, 2017 10:46 AM
justanotherhemi
27
Nov 18, 2012 06:59 AM
H2Miami
Apr 3, 2012 06:56 PM
red92901
Jun 20, 2010 06:07 PM
