H2 with Rancho lift oil pan removal
Old May 7, 2022 | 09:05 AM
Eddy Lee's Avatar
Default H2 with Rancho lift oil pan removal
I have a 2004 H2 with Rancho 4" lift. I need to replace the oil pan gasket, I have no problem clearing the front diff because of the lift. But the Rancho sub frame assembly gets in the way by about 1/2 an inch. This is a welded item and does not have a bolt on cross member. Has anyone ever done one of these as I cannot see how it can be done without complete disassembly. Already taken all the bolts out of the oil pan so now stuck in my garage. Help
Old May 7, 2022 | 12:00 PM
legerwn's Avatar
lift the engine, might need to remove motor mount bolts also
Neal
Old May 7, 2022 | 12:05 PM
Eddy Lee's Avatar
Thanks very much, I considered this but just not equiped to do it. I would take it to a garage with a lift but as the pan is now off I cant move it until resolved.
Old May 8, 2022 | 06:00 PM
might be able to gain some clearance in the rear if you remove the transmission mount and carefully jack up the transfer case. maybe it will give some extra space.
Old May 8, 2022 | 07:03 PM
Eddy Lee's Avatar
Good idea I will try that tomorrow if I have a big enough jack.
Old May 8, 2022 | 08:04 PM
4 Ton Hydraulic Bottle Jack will be a big enough jack.
Eddy Lee
May 9, 2022 12:32 PM
hmer
Jan 20, 2015 07:17 AM
Caraddict
Jul 3, 2014 01:11 PM
jntfj80
Jun 23, 2013 10:55 AM
h2_32137
Mar 24, 2010 01:38 AM
