H2 Interior Fuse Block Replacement
Old Dec 13, 2023 | 11:40 AM
PGI Conch's Avatar
Default H2 Interior Fuse Block Replacement
I have to replace the interior fuse block (left side of dash). From looking at the replacement it would appear that i only need to remove the two connectors (left side of block), pinch the top and bottom release tabs of the block and pull it out to access the screw that holds the rear main connector on, then remove the rear connector. Anyone that has removed this block know if this plan is feasible or will I have to remove the dash pieces to actually get it out? TIA for any advice.
Old Jan 4, 2024 | 04:52 PM
PGI Conch's Avatar
Default Job Done
Ok, hadn't gotten any responses but got some time and went at it. To answer my own question, NO. Left side dash cowling and knee cowl have to come out, along with the headlights switch assembly. And it didn't come out far enough to get a wrench on the rear connector. Had to attack that from above within extender and swivel. Apparently a PO had someone in there before to install a defunct security/remote start system (all removed 1st week of my ownership) and they never put the fuse block back all the way into the framing clips which explained why I had to hold it when removing fuses from the original unit. Anyway, all done, locked back in and everything work with no loss of power to the PDM. Have yet to disassemble the original to see why it crapped out.
Old Jan 7, 2024 | 09:08 AM
Gavin Costigan's Avatar
Nicely done. Can’t say at least in my time on the forum that I’ve seen an interior fuse block issue.
Old Jan 7, 2024 | 02:45 PM
PGI Conch's Avatar
Yeah, it's weird. Pull the fuse for PDM and get continuity between the fuse pins and backside connector pins. Push the fuse in all the way and it loses continuity from the fuse to output pin on the rear connector side. Unfortunately it appears that I have to destroy the center metal pin/connector socket to get a look inside to see just what is happening. I may get to that and will post pics of findings. Not sure if it's a PCB or actual wiring inside.
Old Jan 18, 2025 | 08:37 PM
senseofhummer's Avatar
I will be looking into mine to see if the speaker wires coming from the amp to the driver tweeter and door speaker are loose on the backside. I know this thread is a little old but am curious if you can get a hand in there to feel around the wiring without having to pull apart too much. I finally found the full radio/amp/speaker wiring online. I'd bet things got loose when someone put a remote start into mine (prior owner).
Old Jan 19, 2025 | 06:31 AM
PGI Conch's Avatar
Neither the radio, amp or speaker wires go thru the IP Fuse block.
Old Jan 19, 2025 | 07:39 AM
I made a post about my issue here: https://www.hummerforums.com/forum/h...-2005-a-48709/
In my 2005 H2 SUT the front speaker wires do pass through the I/P relay in the fuse blocks at either side of the dash. Would appreciate any insight on how to remove the cowl below the steering wheel or any other tip for access. Thanks!
PGI Conch
Dec 4, 2023 05:04 PM
Andrew Tebbano
Aug 5, 2023 12:11 PM
chevin
Sep 6, 2018 01:56 AM
JerseyJoe
Jul 20, 2017 12:08 PM
JerseyJoe
Nov 8, 2015 05:39 PM
