H2 Fuel Tank Vent and Rollover Valves
Old Nov 2, 2025 | 06:52 AM
Jack America's Avatar
Default H2 Fuel Tank Vent and Rollover Valves
Checking to see if anyone has replaced or repaired the fuel tank vent valve and the fuel tank rollover vent valve on their Hummer H2.
I have a 2005 Hummer H2 and it seems this will be my next EVAP mission.
1) Did you repair them and how, or did you replace them?
2) What parts did you use to replace them? Which parts are the closest match to the original? (from another GMC or vehicle, part #)
3) Was getting out the originals a pain?
4) How did you reseat the new parts?
I have another thread that talks about the problem I am having and everything I had repaired up to this point of needing to replace these vent valves
"Tighten Fuel Cap" Rabbit Hole - Hummer Forums - Enthusiast Forum for Hummer Owners
https://www.hummerforums.com/forum/h...it-hole-49044/
Old Nov 6, 2025 | 08:16 PM
Mark R's Avatar
If Your talking about the Vent valve on top of the tank mine was replaced by the dealer. Except since he had done so many H2's mine being a 2009 this is what he did.
Instead of dropping the tank to get to the vale on top...... he went out and bought a closet door full length mirror. Glued some hefty magnets to each corner. Then put my 2 on the lift and inserted the mirror over the tank and it stuck to the floor.
Then he got his drop light and hooked it up so he could see in the mirror and worked in reverse (Took Some Practice) and removed and installed the new valve looking in the mirror.
Since he was an experienced HUMMER Mechanic and worked at a HUMMER dealership... He came up with an easy way of doing it and making extra money in the given time.
And that's the way it went.
Old Nov 12, 2025 | 01:41 PM
Gavin Costigan's Avatar
I just pulled mine out through the driver rear fender liner. Can't see **** but easy enough to do by feel. Just remove the liner. Hardest part is the clip that holds it to the tank and the push lock connectors on the hoses.
Old Nov 12, 2025 | 02:06 PM
Mark R's Avatar
Sounds like a good way to go... Just some time and calmness and a Box of Band Aids for the Blood...L.O.L.
myrddin
May 2, 2025 10:11 AM
gearheadib
Sep 1, 2024 07:32 PM
Zco
Aug 4, 2022 11:53 AM
Dannos H2
Nov 18, 2018 03:25 PM
SHOTGUN924
Apr 25, 2013 07:34 AM
