H2 2008 High Beam Relay Location
Old Nov 10, 2022 | 11:12 AM
oceanbrave's Avatar
Default H2 2008 High Beam Relay Location
Does anyone know where to find the above (asking for a friend)
My guess is a PCB underside of the fuse box, very different to earlier years.
Any help very much appreciated.
Old Nov 10, 2022 | 01:43 PM
Service manual says it is in the underhood fuse block but.... it is non-serviceable.
"Important: Relays listed below are non-serviceable Printed Circuit Board (PCB) relays and are internal to the block."
"-- HI BEAM PCB Relay -- HI HEADLAMP - LT Fuse, HI HEADLAMP - RT Fuse"
Old Nov 10, 2022 | 02:51 PM
oceanbrave's Avatar
Thanks @MixManSC that's is what I've read too.
The diagram says HI-Beam PCB relay, and as you say it's non-serviceable.
Just watched a YT video on a GMC Silverado, the box layout is slightly different but the format with plastic handles either side looks similar.
The narrator talks about de-soldering the relay mounted underneath, that's my thinking at the moment - some pictures of the underside would be good.
Old Nov 10, 2022 | 03:14 PM
oceanbrave's Avatar
Update
Think its P/N GM 20806094 and the underside looks like below, probably take a bit of re-working or just replace (if available)
Old Nov 10, 2022 | 03:57 PM
maybe relocate the relay to an empty relay provision on the fuse box. i had to do that for a dodge TIPM fuel pump relay was integrated to the board. benefit was now it had a normal externally serviceable relay.
Old Nov 10, 2022 | 04:04 PM
oceanbrave's Avatar
bronxteck indeed that's a good idea.
This 08 has modified headlights, so I'm wonder if they've over-loaded the contacts as some point, who knows.
eddieman1
Jul 29, 2022 08:48 AM
mguerra
Private 'Wanted' Classifieds
Apr 6, 2022 02:47 PM
mikesbaron
Jan 6, 2022 07:42 AM
kevino
Jan 28, 2019 07:55 AM
JerseyJoe
Nov 8, 2015 05:39 PM
