Grill Guards fitting, Help please
Old Apr 27, 2023 | 12:46 PM
C4EVY's Avatar
Default Grill Guards fitting, Help please
Quick question please, I've managed to get my self a couple of Grill Guards 1 chrome and one black, looked for a you tube video about fitting, but can only find ones being fitted to a pre 2007 H2 mines a 2008 and the bit below the main 7 bar chrome grill looks different (like its part of the top bit, is the grill 1 part or 2 part like 03-07? please, I think the guard will fit once i get the grill / grills off. also can anyone tell me what size bolts are as my car has got the holes but not the bolts Thanks In advance, Oh and thinking of getting the black one powder coated or painted to match my truck..
Eamonn
Old Apr 29, 2023 | 04:25 PM
Brunob00's Avatar
I have to take mine off my 2008 H2 this week to upgrade the headlights... I will let you know what I find... you are correct that the fit for 2008/2009 is different. I will get you photos of what is on my H2.
Old Apr 29, 2023 | 05:03 PM
C4EVY's Avatar
That would be great Thanks, My grill guard is now at the body shop getting painted, and photos of how it fits will be a great help,Cheers Eamonn
Old Apr 30, 2023 | 01:36 PM
C4EVY's Avatar
Managed to get the bolts I needed today and took the whole grill off The small grill under the main chrome one is separate but it's easier to remove the whole big 7 bar chrome one to separate.
I then put the stainless Grill Guard one, then added my Convoy duck "good buddy"
Very pleased with the look, but will decide next week when the one painted to match the Solar Flare color of my Hummer arrives.
Old Apr 30, 2023 | 04:51 PM
so what bolts where necessary incase some one comes across the same issue as you?
Old Apr 30, 2023 | 07:12 PM
Brunob00's Avatar
Looked at mine as well... Here are the steps...
1) You have to remove that small black grille under the chrome grille that says Hummer.
It has 4 clips... two at the top center to connect to the chrome grill and 2 on the side to connect to the body
2) You have to pull that grille off. To get that off without taking off the chrome grille that it is connected to you have to open up the hood and stretch to release the top two clips from the chrome grill.
3. That will loosen it up. Close the hood and you have to pull and wiggle the other clips out. Behind it are the hinges for the hood that the Brush guard mount to.
Now.. interestingly, while the brush guard is connected with 4 bolts... mine was connected with just 2.... so now I need to hunt some down.
Here is the bolt labelled SFT 10.9 which is the grade... not the size. I will need to pull this apart and figure out the bolt size.
On the inside, I can see it is a tapered bolt
Old May 1, 2023 | 02:15 AM
C4EVY's Avatar
send me your address and I'll pop a couple of bolts in the post for you fella, I ended up buying a box of 50 and needed 4 lol.. so I have spares
Old May 6, 2023 | 04:25 PM
Brunob00's Avatar
@C4EVY - Thanks for the offer! I actually found these on gmpartsdirect.com for like $2... so I should be good!
These are the screws needed for the brush guard:
M10x1.5x30 Multi-Purpose Bolt - GM (11516328)
linemn1
Nov 27, 2012 08:41 PM
Flyby22
Jun 22, 2010 09:59 AM
No more Jeeps
Mar 16, 2010 09:25 PM
davidcctx
Oct 22, 2009 08:24 AM
timpossible
Apr 9, 2009 06:28 PM
