Front wiper motor internal plastic gear.
Old Dec 7, 2020 | 10:37 AM
Sting's Avatar
Default Front wiper motor internal plastic gear.
Just searched the internet and this forum but didn't find anything as far as where to purchase one. Need ASAP.
Any help? Thanks in advance.
Old Dec 7, 2020 | 01:21 PM
The gear is not a separate part that you can buy.....
https://www.ebay.com/itm/Windshield-...-/353055253869
Old Dec 8, 2020 | 04:34 AM
oceanbrave's Avatar
Note, the gear houses a small magnet which interacts with a hall-effect sensor on the PCB.
Old Dec 8, 2020 | 10:17 AM
Sting's Avatar
What does PCB stand for?
Do you know where to purchase one?
Old Dec 8, 2020 | 02:54 PM
PCB = printed circuit board.
I gave a link in my first post for one but not the gear by itself.
Old Dec 8, 2020 | 06:02 PM
Cardone remans the 19150497(03-07)
Make a call and ask them for the gear: 800-777-4780 or 888-280-TECH
Old Dec 10, 2020 | 12:28 PM
oceanbrave's Avatar
If the plastic gear is shot you may well have other issues, check the motor and plastic-gear shafts to see if their bearings need replacing.
RA stocks 19150497 for $247.79, if you going to the trouble of accessing the wiper motor why not replace it, surely you don't want to revisit it again?
Also check for "play" in the "Wiper Transmission Linkage". If you hear a "clunk" when the wiper-arms change direction, you may find their shaft bushes are worn. The noise is not the main issue, it's the "lift" in the wiper blade causing it not to clear the windshield properly.
Old Dec 10, 2020 | 08:38 PM
Sting's Avatar
https://youtu.be/S8mn0jORqkk
I've used their parts in my shop and steer clear from them. Poor quality in their workmanship.
I've seen parts that were poorly cleaned and painted from the junkyard.
Old Dec 10, 2020 | 09:25 PM
WTF? You asked for a replacement gear, now you post a copy from a bs review for wm replacement.
Btw, if the wiper motor housing was "poorly cleaned and painted from the junkyard", that doesn't affect the performance!
What's inside matters!
Old Dec 10, 2020 | 11:10 PM
Sting's Avatar
No. I didn't post any copy of a bs review. I replied to the recommendation for a Reman. From a company that paints over grime to be more acurate.
What a predicament, charging a customer for a new reman. in that condition, then being confronted by the customer afterwards and telling the customer, Oh "Whats inside that matters! 🙄
No thank you. 😉
oceanbrave
Mar 20, 2020 06:28 AM
metzlyov
Mar 11, 2018 08:09 AM
Travis Stillwell
Sep 3, 2013 11:04 AM
jayebrewer
Nov 28, 2011 04:25 PM
hectour
Aug 3, 2011 06:41 PM
