Front lower crossmember Torque Specs 4 Frame bolts and Nuts
Sorry first time use at this site and meant no harm I
wasnt sure the mesaage was placed in the right location to get an answer yet 4 times.
I have a Hummer H2 but its also an SUT so again wasn't sure it was sent to the right forum for an answer.
Thanks again for notifying me on this.
Assist Step Nuts
50 N·m
37 lb ft
Body Mounting Bolt
85 N·m
63 lb ft
Catalytic Converter Guard Bolts
30 N·m
22 lb ft
Engine Protection Shield Bolts
30 N·m
22 lb ft
First Crossmember Heat Shield Nuts
12 N·m
106 lb in
Frame Front Heat Shield Bolts
12 N·m
106 lb in
Fuel Tank Crossmember Heat Shield
12 N·m
106 lb in
Fuel Tank Shield Bolt
25 N·m
18 lb ft
Fuel Tank Shield Nut - Inboard
9 N·m
80 lb in
Fuel Tank Shield Nuts - Outboard
18 N·m
13 lb ft
Lower Control Arm Crossmember nuts
90 N·m
66 lb ft
Rocker Panel Protector Bolts
85 N·m
63 lb ft
Spare Wheel Carrier
100 N·m
74 lb ft
Tow Hook to Frame Rail Bolts
95 N·m
70 lb ft
Trailer Hitch to Frame Bolts
85 N·m
63 lb ft
Transfer Case Shield Bolts
30 N·m
22 lb ft
Transmission Mount to Support Bolts
40 N·m
30 lb ft
Transmission Support Crossmember Heat Shield Bolts
12 N·m
106 lb in
Transmission Support to Frame Bolts
95 N·m
70 lb ft
Winch Receiver Bolts
85 N·m
63 lb ft
Differential Adjuster Lock Nut Bolt
20 N·m
15 lb ft
Differential Carrier Case Bolt
78 N·m
58 lb ft
Differential Carrier Assembly Bolt/Nut
100 N·m
75 lb ft
Differential Carrier Assembly Hole Plug
28 N·m
21 lb ft
Front Axle Drain/Fill Plug
33 N·m
24 lb ft
Inner Axle Shaft Housing Nut
100 N·m
75 lb ft
Inner Axle Shaft Housing Bolt
40 N·m
30 lb ft
Pinion Shaft Lock Bolt
50 N·m
37 lb ft
Ring Gear Bolt
138 N·m
102 lb ft
Vent Hose Connector
20 N·m
15 lb ft
Wheel Drive Shaft Inboard Flange-to-Axle Shaft Bolt
79 N·m
58 lb ft
Adapter Bolts to Transmission
50 N·m
37 lb ft
Adapter Studs
10 N·m
89 lb in
Case Bolts
21 N·m
15 lb ft
Crossmember Bolts
95 N·m
70 lb ft
Drain Plug
25 N·m
18 lb ft
Encoder Motor Bolts
10 N·m
89 lb in
Encoder Motor Bracket Bolt
10 N·m
89 lb in
Fill Plug
25 N·m
18 lb ft
Transfer Case Mounting Nuts
50 N·m
37 lb ft
20 N·m
15 lb ft
Vehicle Speed Sensors
17 N·m
13 lb ft
Vent
6 N·m
53 lb in
50 N·m
37 lb ft
Body Mounting Bolt
85 N·m
63 lb ft
30 N·m
22 lb ft
30 N·m
22 lb ft
12 N·m
106 lb in
12 N·m
106 lb in
12 N·m
106 lb in
25 N·m
18 lb ft
9 N·m
80 lb in
18 N·m
13 lb ft
90 N·m
66 lb ft
85 N·m
63 lb ft
Spare Wheel Carrier
100 N·m
74 lb ft
95 N·m
70 lb ft
85 N·m
63 lb ft
30 N·m
22 lb ft
40 N·m
30 lb ft
12 N·m
106 lb in
95 N·m
70 lb ft
85 N·m
63 lb ft
20 N·m
15 lb ft
78 N·m
58 lb ft
100 N·m
75 lb ft
28 N·m
21 lb ft
33 N·m
24 lb ft
100 N·m
75 lb ft
40 N·m
30 lb ft
50 N·m
37 lb ft
Ring Gear Bolt
138 N·m
102 lb ft
Vent Hose Connector
20 N·m
15 lb ft
79 N·m
58 lb ft
50 N·m
37 lb ft
Adapter Studs
10 N·m
89 lb in
Case Bolts
21 N·m
15 lb ft
Crossmember Bolts
95 N·m
70 lb ft
Drain Plug
25 N·m
18 lb ft
Encoder Motor Bolts
10 N·m
89 lb in
10 N·m
89 lb in
Fill Plug
25 N·m
18 lb ft
50 N·m
37 lb ft
20 N·m
15 lb ft
17 N·m
13 lb ft
Vent
6 N·m
53 lb in
MixManSc
Maybe you can help im going to change oil pan gasket.
Question : In order to drop differential for clearance of removing the oil pan do all the Three Carrier assembly nuts and bolts holding the differential have to be fully removed.This means the three one is on lower left side of the lower arm crossmember bracket and other one is on the right side of the front axle and the third one is at top drivers side above differential.Thanks
