Front Lower control arms
Hi everyone, I bought a kryptonite kit. And I have questions for my upcoming project. Has anyone had luck getting the torsion bars out of the lower control arms with success? And tips?
Any tips with the whole front end replacement would be appreciated as well.
Replacing, front uppers, bushings ball joints, front axles, tie rods and center link, Pittman and idler with support
You need to buy the torsion bar tool to relieve the pressure and then its pretty much cake.
The rest is also easy, just take one piece off at a time, try to count turns with tie rods so that you can get it back together with some sort of alignement, then take it to the tire store and have professionally aligned.
Don't forget bump stops while you are there.
I would recommend removing the front axles first, for easy access to the ball joint bolts. Do your lower ball joint/ control arm and let the knuckle hang from the upper and ratchet strap it up. Then do the upper when the lower is back in place.
Steering box has to come out to get the pitman arm off and you'll need a crows foot 1-13/16 if you plan on actually torquing the nut with a torque wrench.
Lastly you don't need the idler support. It's a pain in the *** and in my experience doesn't really do anything.
hnijhar
Oct 27, 2019 05:15 PM
lostsoul77
Mar 25, 2015 08:41 PM
skicranmore
Sep 24, 2014 08:36 AM
