Front License Plate Bracket Suggestions
Old May 12, 2023 | 08:38 PM
spyromike's Avatar
Default Front License Plate Bracket Suggestions
Hello,
Instead of bumping old threads on the topic, I was wondering if anyone has come across any decent mounting brackets for the front license plate. I have a 2008 H2. It appears I can just pop the plastic covers off the screw holes and mount the plate directly by the top 2 holes, but there's nothing to support the rest of the plate.
I would love to see what brackets/mounts you have used or entertain your suggestions. In my state we are supposed to run a front plate so I'm trying to give them one less reason to pull us over. Thanks in advance for your help.
Old May 13, 2023 | 08:27 AM
Hummer2's Avatar
Originally Posted by spyromike
Hello,
those holes are the license plate bracket.
Old May 13, 2023 | 08:44 AM
Hummer2's Avatar
https://www.ebay.com/itm/19459968679...mis&media=COPY
Old May 13, 2023 | 09:57 AM
Brunob00's Avatar
Gobi sells this specifically for that spot on the Hummer H2...
https://gobiracks.com/product/gobi-license-plate-cover/
Old May 13, 2023 | 10:07 AM
Brunob00's Avatar
If you want stick to OEM... this is the GM part... looks like it is still available, and appears on eBay.
License Plate Bracket - GM (15176139)
Old May 13, 2023 | 12:15 PM
spyromike's Avatar
A little pricey but its perfect. Thanks!
Old May 14, 2023 | 02:56 PM
Hummer2's Avatar
it looks like the plate bracket was used on about every GM car during those years. The junk yards should be full of them.
Old May 18, 2023 | 09:12 PM
finall's Avatar
I run the OEM bracket. Perfect.
But beware, you will need the nylon bumper inserts for whatever size of screws you plan on using. Those are pushed into the holes when u pull the plugs out. And they in themselves need to be the right size for the square holes.
spyromike
Oct 23, 2021 01:56 PM
JDEORTA
83
Feb 17, 2015 08:20 PM
BIGT2148
Aug 4, 2010 05:28 PM
JTummer
Oct 1, 2008 09:24 PM
haiminger
Nov 26, 2007 08:07 PM
