Front Diff. Bushings Upgrades
Old May 12, 2017 | 04:06 PM
citiboy's Avatar
Default Front Diff. Bushings Upgrades
Upgraded my H2 front diff. and crossmember bushings from Outfitter Design. Also, replaced front diff. 2 outer seal with OEM and replaced 2 front u-joints with Spicer.
Old May 13, 2017 | 08:04 AM
calif phil's Avatar
Great job. What did you do to the diff? Did you pick up any extra vibrations with the heavy duty bushings?
Old May 13, 2017 | 08:17 AM
citiboy's Avatar
I didn't do any mods to the diff except replaced 2 outer seal that's leaking. No vibrations at all, it actually eliminates clunk. Will see if this hold up off-road.
Old May 18, 2017 | 02:13 PM
iwillnc's Avatar
Did you have to split the case open to replace the seals?
Old May 18, 2017 | 02:33 PM
citiboy's Avatar
no, i just removed the diff. output shaft flange.
Old May 18, 2017 | 03:40 PM
iwillnc's Avatar
It just pops out by pulling on it?
Old May 18, 2017 | 03:50 PM
citiboy's Avatar
i just tap the flange edge lightly with the rubber mallet and it came out fine. You can use a sliding hammer if you have one available and it'll do the same job.
Old May 19, 2017 | 05:20 AM
elkgrunt's Avatar
Nice job
Old May 22, 2017 | 12:19 PM
legerwn's Avatar
Thanks for the pics, headed out to change the oil pan gasket and will drop the diff to make it easier the pics will help out a lot.
Neall
Old Jun 4, 2017 | 02:54 AM
gopantherpride's Avatar
How bad was your clunk? I've got the clunk that is audible when I let off the throttle and then reapply. Not so much when shifting from gear to gear. I just came across the Outfitter bushing kit and am seriously considering the upgrade but want to do gear swap at the same time. I've got the oem 3.73s and want the 4.56s to go with the 37s I'm running.
