Flickering lights
Old Nov 14, 2019 | 11:07 PM
Elkrazymono's Avatar
Default Flickering lights
Ok so I was wondering if anyone has came across some flickering lights on 03 h2. All the lights flicker inside and outside. I did notice that when I accelerate it makes my lights flicker faster.
Old Nov 15, 2019 | 08:07 AM
Welcome to HF. MOVED your thread to the H2 section......... where all H2 questions go.
Old Nov 15, 2019 | 10:03 AM
Sounds like your battery is about to die on you and it is mostly running on the distributor.
Old Nov 15, 2019 | 09:57 PM
Ok thank you ima get my battery checked out, I know it's not original battery on here, probably dont even have enough cold cranking amps either.
Old Nov 16, 2019 | 07:45 AM
calif phil's Avatar
Loose or corroded battery cables is another quick easy place to look.
loud pipes
Sep 5, 2020 07:21 AM
AverageWeekend
Dec 12, 2016 07:07 AM
drtom
Aug 4, 2010 03:23 AM
Chameleon
Mar 9, 2009 08:20 PM
schannel
Aug 17, 2007 03:30 AM
