Evap Pipe Supplier?
Old Aug 6, 2020 | 10:15 AM
  #21
while you have the tank down. do you think it would be simpler to do the brake lines at this point without having to lift the body? since you already have had the experience.
Old Aug 6, 2020 | 11:47 AM
  #22
oceanbrave's Avatar
bronxteck I'll take a look and come back on that point.
Old Aug 6, 2020 | 12:11 PM
  #23
oceanbrave's Avatar
bronxteck this looks like "Yes" see video taken today in response to your question
Old Aug 6, 2020 | 02:29 PM
  #24
so if you had to do it again which method would you choose? drop the tank. or lift the cab.
i loved the video.
Old Aug 6, 2020 | 05:19 PM
  #25
oceanbrave's Avatar
60/40 drop the tank as it provides much better access to routing the lines and allows inspection of the fpm, which is possibly in the same state.
If I'd have known my pump was going, then 100%
Old Aug 6, 2020 | 06:49 PM
  #26
https://www.youtube.com/watch?v=cFgyX6-CFFc
Great video, especially your accent(I got a man crush on gordon ramsay) Now you have experience to share for years to come. Find a way to secure the evap line(tie strap works too)
“You’re getting your knickers in a twist! Calm down!”
Old Aug 7, 2020 | 04:32 AM
  #27
oceanbrave's Avatar
Unfortunately I don't have his looks, hence you can't see my face
Old Aug 7, 2020 | 08:06 AM
  #28
oceanbrave's Avatar
Question - Does the fuel line need priming or will it run OK?
Old Aug 7, 2020 | 08:10 AM
  #29
oceanbrave's Avatar
Ah looks like its self primg...thank you ..calif phil it was an old post
Old Aug 7, 2020 | 02:53 PM
  #30
Yes, just add fuel to the tank, and cycle KOEO a couple times. Check for leaks, then start it up.
