Engine light 2003 H2 Help...
Old Feb 7, 2008 | 06:40 PM
Significant's Avatar
Default RE: Engine light 2003 H2 Help...
sorry it might only be accessable for technicians... ill try to get something up for you...
Old May 24, 2011 | 01:51 PM
TowDawg's Avatar
Any new info on this?
I know it's an old thread, but I just threw P0455. The auto parts place said it was the Evap Purge Cylinder (which showed on the drawing to be right near/on the throttle body), but after reading this thread, it sounds like it could be a number of things.
Just hoping someone can give an update on other things to look for or supply the info that is in the non-working link.
Thanks,
Scott
Old May 24, 2011 | 03:55 PM
08JJ's Avatar
You can go through the trouble of a smoke test....NTB and others do it for about $100.....most likely its a vacuum hose leak if its not the gas cap.
Old May 25, 2011 | 05:34 PM
luda81's Avatar
how is your engine running? if it was the purge it should be running rich I think.
Old May 26, 2011 | 03:51 PM
TowDawg's Avatar
Car is running just fine. I cleared the code 2 days ago and it hasn't come back yet. We'll see how long it stays off and then I'll start digging around underneath and see if I find any loose, rotted or torn hoses.
Old May 30, 2011 | 10:34 AM
luda81's Avatar
"I don't care about the "Jeep thing" as long as my mail is on time!!!"
NOW THATS FUNNY!!!!!!!
Old May 30, 2011 | 07:40 PM
bigginsgsxr's Avatar
Default Water problem
Hello everyone I am a new member but not a new Hummer owner. I have had my H2 for about 3 years now with never a problem. Now I have a problem, every time it rain or I go to wash it I get a decent sized puddle on my drivers side floor. So much that I have to use the shop vac to get all the water out. I have tried experiment with the moon roof, the door seal, and the hood vents and came up with nothing. Any ideas? I asked a friend of mine that owns a big SUV and said to check the roof drains? Thanks in advance.
Poweraidion
Feb 16, 2014 11:26 AM
key2pwr
Nov 5, 2010 04:06 PM
joenuzz
Aug 21, 2010 10:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
jaeger
Nov 17, 2008 12:38 AM
