Engine light 2003 H2 Help...
Old Feb 5, 2008 | 06:28 PM
flrtrader's Avatar
Default Engine light 2003 H2 Help...
Hi,
New to the forum and am having a problem I can't seem to tackle. Engine light came on a few weeks ago and I took it into Autozone to have the code read, Which was PO455
At the time they said it looked like a gas cap issue and mine was not tightning as it sould so I replaced it, they reset the light and said here's hopping it stays off! Well I was happy cause it stayed of for almost a week, BUT today she popped back on,... I stopped back by to get another code read and was told it was the same code, but now with the cap replaced it was saying a large leak in the evap system which could be evap can broke, hose cracked or fell off, or purge or vent selinoid defective, or... vacum leak at engine. I feel stupid but I have no idea where the Evap canister is, and could find nothing pointing me at it. I don't think its a Vac leak at the engine cause the motor runs perfect, not a miss... not a sputter... So... if any one of you really kind people can help with the code, first place you'd look ect. Actually a pic of the evac canister might help....
Thanks in advance....
Old Feb 5, 2008 | 06:43 PM
Muddydawg75's Avatar
Default RE: Engine light 2003 H2 Help...
I had the vent solenoid replaced for p0446 and also the cannister for p0446...
I think p0445 is for the relief valve on the top of your gas tank...
Old Feb 5, 2008 | 08:30 PM
blackstangs281's Avatar
The canister is located on the drivers side frame, about mid vehicle.
Old Feb 5, 2008 | 08:36 PM
The 455 code is a large leak in the system. If it is not the cap, then a line or hose has to be off or cracked. Or it could be a purge valve stuck open.
The H2 runs a check in between 1/4 and 3/4 tank of gas. That may explain why the light did not come back on right away. If you keep your tank full or above 3/4 it will not tag the light. As soon as it drops below that, it runs a check on the system.
Check all the vent lines to make sure one has not come off.
Old Feb 5, 2008 | 09:26 PM
pteam's Avatar
Good info here.
Old Feb 6, 2008 | 02:14 PM
flrtrader's Avatar
Thanks Blackstang,
I located the canister and crawed all around it... the can looked like new... none of the three hoses off or loose One large and two smaller. I evenlistened cause you'd think with a magor leak one would hear the sucking sound? But nope... crawled all over the engine... could find not obvious leaks, cracks... ect. Im stumpted cause Im not a silly, stupid man in my prime I even built a few racing engines.. so this is actually rediculas! GRrrr.. Besides the 100 dollar bill my hummer dealer wants just to run a diagnostic! They are like 60 miles away.. Im in construction and we work daylight till dark so I'll need to rent a car, just to drop my beast off... I mean she's worth every dime but dang it just seems....
Old Feb 6, 2008 | 04:42 PM
so... while you were under there did you check the relief valve on the tank?
Old Feb 6, 2008 | 11:59 PM
Significant's Avatar
this should help you out on solving your problem... http://service.gm.com/servlets/BlobS...732&evc=sm
Old Feb 7, 2008 | 08:04 AM
ebrown's Avatar
that link doesnt work for me.....
Old Feb 7, 2008 | 09:47 AM
I couldn't get the link to work either.
