ECU/ECM needs to be reset constantly ! help
Old Mar 13, 2019 | 04:42 PM
Priuscrusher's Avatar
Default ECU/ECM needs to be reset constantly ! help
help me Hummer experts
2004 H2 , 100K miles, K&N cold air intake
last summer my engine temp gauge went crazy showing it was boiling hot way past the max.....I also had poor acceleration and needed to back off the throttle to speed up.....it was 100 degrees in florida …..I disconnected the battery and it reset the gauge and the Hummer drove great......then it did it again a month later, shows a 3xx code and knock sensor issue and temp gauge buried past red......I cleared the codes, reset by disconnecting the battery......sometimes it resets perfectly and sometimes it takes 3 or 4 resets to drive correctly......same thing everytime…...super sluggish throttle, cant give it too much gas or it wont go, barely touch the pedal and it accelerates, engine light comes on and code shows knock sensor, wont shift properly, or downshift...…….disconnect battery and it runs perfectly
its almost like a need a battery disconnect in the cab to quick fix the problem...….it did this while in locked low crawling in a claypit recently and I again had to get out and disconnect the batteryreset ecm to get out of the woods
any ideas ??? it runs perfectly for a little while and then resets itself to crap mode for no reason
Old Mar 13, 2019 | 05:39 PM
Have you replaced the knock sensors?
Old Mar 13, 2019 | 05:46 PM
No.......I didn’t because of the fact that when I disconnect the battery/reset it runs perfectly and never ever those codes or misfires and it takes a while to show a code about a misfire......the misfire code doesn’t always show up right away , I have to drive it stumbling and no power, poor shifting for a while before it shows the code
Old Mar 13, 2019 | 07:02 PM
First thing I might try would be to verify that all the grounds and good and solid. Could probably find a lot more tips on one of the GM truck forums since the trucks are far more common and use essentially the same engine and electrical system. Just an odd one and troubleshooting something that is so random is not always easy.
I'm not sure what the ECU does if it does detect severe predetonation (knock) but it very well might be the knock sensors and its going into a sort of limp or safety mode by drastically cutting the timing or something to prevent engine damage.
If you have ever cleaned well under the hood (quite likely since you go wheeling) then its possible water got in and the knock sensors are corroded and rusty. Common problem on GM trucks - they are directly under the intake manifold. There is a foam block to prevent stuff from getting in there but it does. If you are not aware, NEVER direct water to the top front of the engine under the air intake tube. It can and will get past the foam block and run under the intake. I've replaced mine, not terribly hard but not at all fun to do.
kitcheneater
Jun 26, 2018 06:57 AM
H2Miami
Mar 17, 2017 10:31 AM
Hummy
Dec 4, 2011 01:12 AM
therobesons
Nov 17, 2009 08:49 PM
NoDakH3
Mar 18, 2009 06:50 PM
