Drivers Seat and Memory and Heat
Old Oct 15, 2024 | 01:18 PM
mtlhummer's Avatar
Exclamation Drivers Seat and Memory and Heat
Hello,
I have a 2004 Hummer H2 6.0L V8 and its driver's seat is Not working I have changed the expensive fuses in the footwell both left and right the passenger seat works however no heating for either of them! neither can I move the driver's seat and honestly it would be nice to find a resolution here rather than going to the Dealer.
Old Oct 15, 2024 | 03:35 PM
H2-SUT's Avatar
Its probably the control module/switch assembly in the door that is bad. Many of them were damaged from moisture. I had to replace the one in my 06 because of that. Push the button and nothing happens or the indicator comes on and that's about it.
Old Oct 16, 2024 | 01:35 PM
mtlhummer's Avatar
Does that affect the movement of the seat too? because my seat doesn't move or heat and the psg seats do not heat
Old Oct 18, 2024 | 04:20 AM
oceanbrave's Avatar
@mtlhummer
There are a number of threads on this topic, for example this one shows part of the memory seat module circuit (MSM)
https://www.hummerforums.com/forum/h...er-seat-47193/
The module also controls the front right seat heaters, this suggests the problem lies here. again this thread explores the under seat connector as posted by @finall
https://www.hummerforums.com/forum/h...ng-help-45496/
It might be worth checking the connectors under the seat.
Any diagnostic trouble codes would also be helpful.
Miketheike08H2
Oct 30, 2023 05:44 PM
Harleykids
Mar 4, 2019 09:40 PM
hmer
Mar 24, 2015 05:02 PM
NC_Hummer
Dec 22, 2012 11:48 PM
Smgcabrio
Oct 21, 2010 03:52 AM
