Drivers door squeak
Old Jul 8, 2020 | 10:14 PM
fastNYsix's Avatar
Default Drivers door squeak
My driver door squeaks when I open and close it. The squeak appears to be coming from the black plastic closer arm. There’s scratches on the arm, maybe from a roller dragging. Is there a roller inside the door? Is there any way to service or replace the parts inside the door? I sprayed some silicone and it made very little improvement. Pics would be great. Thanks.
Old Jul 8, 2020 | 10:17 PM
try white lithium grease spray instead.
Old Jul 8, 2020 | 10:46 PM
X2 silicone spray and lithium is all I use!>>>>>>>> BLASTER
Old Jul 9, 2020 | 07:03 AM
fastNYsix's Avatar
The assembly is still available new. Pricey though.
Old Jul 9, 2020 | 08:54 AM
Chrmer3's Avatar
GM Part #
10386076
You can try lube - when that doesnt resolve it - replace this part. Common wear item, I have replaced many of these.
Door panel needs to come off but its a fairly easy project to do....
Ebay has this new one discounted but part number is for rear left door. If I remember correctly it will interchange with the drivers door - I think.
https://www.ebay.com/itm/2003-09-Hum...YAAOSwOdpXybSo
Old Jul 9, 2020 | 11:50 AM
mcioci's Avatar
Originally Posted by Chrmer3
GM Part #
10386076
We have a winner here. I had to change out both front driver side door checks on my trucks. Age will do this to the door checks.
Old Jul 9, 2020 | 01:26 PM
I also changed mine but because they would not hold the doors open. Even the brand new genuine ones I replaced them with still barely can hold the doors open.
Old Jul 9, 2020 | 01:35 PM
LoJac963's Avatar
I replaced all 4 of mine a few years back mainly due to the driver door squeaking but decided just to do all 4 when I was taking all the doors apart to upgrade speakers. Mine were AC Delco and hold the doors open no problem.
Old Jul 16, 2020 | 11:01 PM
clsimmon's Avatar
GM Part #
10386076
Does rear left work for the front left? From what I've seen the front door checks are getting nearly impossible to find.
Old Jul 17, 2020 | 08:30 AM
Chrmer3's Avatar
I am pretty sure the sides are the same (just different part numbers) the difference from side to side is basically a flipped over unit. I believe off memory that it will also work left to right - only difference is the rivet that holds the arm to the bracket at the jamb faces up vs down - however the only way you notice that is if you were looking for it and examined closely.
again- I am pretty sure on this - not 100% but close lol
