Drivers door squeak
My driver door squeaks when I open and close it. The squeak appears to be coming from the black plastic closer arm. There’s scratches on the arm, maybe from a roller dragging. Is there a roller inside the door? Is there any way to service or replace the parts inside the door? I sprayed some silicone and it made very little improvement. Pics would be great. Thanks.
GM Part #
You can try lube - when that doesnt resolve it - replace this part. Common wear item, I have replaced many of these.
Door panel needs to come off but its a fairly easy project to do....
Ebay has this new one discounted but part number is for rear left door. If I remember correctly it will interchange with the drivers door - I think.
https://www.ebay.com/itm/2003-09-Hum...YAAOSwOdpXybSo
10386076
GM Part #
10386076
I replaced all 4 of mine a few years back mainly due to the driver door squeaking but decided just to do all 4 when I was taking all the doors apart to upgrade speakers. Mine were AC Delco and hold the doors open no problem.
GM Part #
10386076
I am pretty sure the sides are the same (just different part numbers) the difference from side to side is basically a flipped over unit. I believe off memory that it will also work left to right - only difference is the rivet that holds the arm to the bracket at the jamb faces up vs down - however the only way you notice that is if you were looking for it and examined closely.
again- I am pretty sure on this - not 100% but close lol
