Driver front door needs adjusting H2
Old Sep 12, 2019 | 10:20 PM
Shiftrus's Avatar
Default Driver front door needs adjusting H2
Hello everyone, how do I adjust the front door to sit closer to the cab when the door is closed? Thanks in advance!!
Old Sep 12, 2019 | 10:49 PM
hummer_on_fumes's Avatar
During a storm with extremely strong wind my brother opened the door and the wind blasted it open. This caused the door to not only be aligned wrong but it wouldn't even shut. You have to open the door and loosen the bolts on the hinges, put the door into the correct position, then tighten them back up.
Old Sep 13, 2019 | 07:07 AM
It also depends on where it needs adjusting. If the overall position of the door is off then adjust the hinges first to get that set. The hinges also adjust the front edge in/out. If at the back edge it sticks out some, in too far, or "hits" the strike meaning it moves up or down any when latching then you can loosen and adjust the strike. The attached document is for adjusting both.
File Type: pdf
Old Sep 13, 2019 | 11:01 AM
grab the bottom outer edge of the door and lift it. if you feel it has play or moves up and down then your hinge pins and bushes need replacing. the dealer only sells half hinges, that is the upper and lower. so 2 separate part numbers to assemble 1 whole hinge.
Old Sep 19, 2019 | 07:47 AM
clsimmon's Avatar
This is an interesting attachment. I had no idea you could adjust the doors, which is great! However, It's difficult to understand what you're looking at. For someone who's actually done this according to the service manual, I'd recommend creating a video. It would be helpful for many.
dkb123
Jun 21, 2022 12:24 PM
Shiftrus
Sep 17, 2019 05:50 PM
Humvee21
Apr 10, 2015 03:28 PM
slider28
Sep 27, 2014 05:11 AM
FALSE FACE
Jun 13, 2010 09:23 PM
