Driver door AJAR, hundreds spent and problem still exists
Old Jan 8, 2013 | 08:59 PM
christianstar's Avatar
Default Driver door AJAR, hundreds spent and problem still exists
Hello all,
I have read ever forum and page on the internet discussing the door ajar issues some H2s get. I myself sell and install electronics in commercial locations so troubleshooting and fixing is a passion of mine.
After reading all fixes I decided to work on mine. I have a 03 H2
First I checked all wires inside the drivers door to the plugs near the fuse panel to the bcm. All appeared good and plugs were tight.
Then I replaced the door actuator/clasp $199. No change
Then I replaced the BCM and had it programmed at the dealer. $225 bcd $90 program. No change
I then figured out that if I press and hold the drivers seat back heat button, the message goes away. So Im guessing the door either has a ground problem or there another module inside the door not working.
I will fix this correctly, any ideas?
Old Jan 9, 2013 | 10:11 PM
2wheelmonster's Avatar
One place you might want to check is the harness where it is located in the door jam. The part where opening and closing the door would wear the coating of the wires down far enough to create that short that is coming up with the problem.
Old Feb 7, 2013 | 10:54 PM
Thumper's Avatar
if its not the harness then its the control module, unfortuately since its the one in the dash where the steering colume is it will have to be dismantled. The unit will run around $200 and labor about $800.
Old Feb 8, 2013 | 09:57 AM
ejweelin06's Avatar
i would guess a ground or a contact issue. could be that by pressing the button you are putting just enough pressure to make the conection either at the latch or in the door
Old Feb 15, 2013 | 12:10 PM
Solved the driver door ajar!!!
Another 165.00 but finally done
After changing the door lock clasp 235.00
Bcm 219.00 plus 1 hour programming at dealership
New door wiring harness 117.00
Countless hours I supplied
The drivers door switch assembly was the problem!!
It has multiple electronics inside it.
That's everything involved. Any questions feel free to contact me!!
Old Feb 18, 2013 | 05:30 PM
calif phil's Avatar
Please clarify, What drivers door switch?
Old Feb 19, 2013 | 08:06 AM
Sorry to clarify ,
Last week I tore the door apart again! Traced every wire and noticed pretty much
Every thing plugs into the master window/door lock switch assembly.
That's when I pryed open the switch assembly and found two circuit boards and corrosion.
So after all that the problem was right in front if me.
It amazes me that they would have such an important set of circuit boards,
Sitting in a place that gets wet everytime the door opens in the rain!!
Any questions?
Old Dec 26, 2015 | 08:48 PM
indian's Avatar
Unhappy right rear door ajar
right rear door ajar on my h2 03 model . after reading your post . could that be my problem on the right rear door or the master switch.
Old Jan 4, 2016 | 08:45 AM
oceanbrave's Avatar
Originally Posted by christianstar
Sorry to clarify ,
Any questions?
Good post!
Old Dec 26, 2017 | 10:25 AM
rswizards17's Avatar
Default Left rear door help
I replace the dirvers window/lock main switch. I still get the left rear door ajar..sets my alarm off..
I have had the door actuator replaced & bcm reflashed.....any other ideas?
