The dreaded door panel removal???
Old Jun 2, 2019 | 07:35 PM
hummer_on_fumes's Avatar
I'm ordering a lock actuator for my passenger rear. I'll update after that arrives in the mail and I make time for the nightmare of doing the swap. If that fix works, I'll order one for the other side. I'm going with a remanufactured OEM instead of a new Chinese one.
Old Jun 7, 2019 | 11:21 PM
Hbrezzi's Avatar
Originally Posted by hummer_on_fumes
Good lord a new actuator for just 1 door is $150. I tried replacing the LOCKS fuse but I'm still having the problem. I guess I'll follow your advice and also remove the passenger front door panel and watch how it moves on a working door. It's weird that both rear actuators would go out at the exact same time though. They are moving, sometimes they'll lock or unlock halfway which is weird, so seems like something mechanical to me and not electronic, but I'm not positive.
Not willing / able to buy original ones, I replaced all 4 door actuators with generic ones ($7 each) and they have been performing well for almost a year now.
While you have to go OEM on certain parts, you can save a bunch on non “critical” ones.
Old Jun 7, 2019 | 11:38 PM
I opted for OEM only becuz I didn't want to have to take the door panel off again if a Chinese one crapped out. But to my surprise taking the door panels off isn't really that bad. I was able to find refurbished OEM actuators on eBay for around $70. The new actuator did fix my problem.
Old Jun 8, 2019 | 10:32 PM
clsimmon's Avatar
Where can you find actuators for $7?
Old Feb 2, 2021 | 11:01 AM
JoeElegar's Avatar
I think the locksmith has provided them the actuator at $7.
Old Feb 2, 2021 | 01:57 PM
clsimmon's Avatar
I believe there is some confusion. The lock actuator is the door latch inside the door that also acts as the door latch. I'm confident locksmiths do not have these in stock nor do they sell them for $7. Each lock actuator is unique to that door. The H2 has 4 different part numbers for all 4 doors and it is not shared with any other GM vehicle.
slider28
Sep 27, 2014 05:11 AM
BIGT2148
Oct 20, 2009 12:57 PM
wfturner
Oct 18, 2009 09:20 AM
quadblaster240
Aug 28, 2009 01:37 PM
DMoneyTT
Feb 6, 2008 06:40 PM
